spotted a silver r32 gts in hartwell around 5:45pm, just going under the train bridge, was following for a min or two.
wes***
spotted a white r34 on highbury rd around 6pm heading vermont sth direction, didnt catch the plates.
wes***
Hrmm might be me? I was on turning onto highbury road from springvale road at about 6:15p.m but didnt see a Stagea though :P
Are you the r34 that lives in that street off highbury road with the black hood? Always see it when I go for a run.
Nah not me, don't have a black hood just a white R34 with bronze TE37's.
But yeah i do live just off highbury road :D
nah, i was up at the bp near the new hungry jacks on blackburn rd.
the r34 was heading towards springy.
hear boostn0199 most nights coming home down robinson.
Hrmm might be me? I was on turning onto highbury road from springvale road at about 6:15p.m but didnt see a Stagea though :D
Where do you live? in robinson aswell?
Silver S2 r33 behind me in seaford maccas drive throw, ooked like it had sau stickers from wht i could see out of my mirrors when leaving spotted a grey 32 with a red p plate crossing franga dandy rd.
^fark havent seen her around in a while. she used to be committee didnt she?
yeah I've been busy :P I live in Werribee now..
I've seen plenty of peeps round Hoppers Crossing and Geelong recently but no SAU Stix.. well except for the white.. err 34? I beeped at when going past me the other week in Werribee with SAU Stix.. you live like 2 streets away from me. There's a black 32 or 33 that lives almost directly behind me too (I forget which).
Saw some guy in a.. 33? in Drysdale the other week... can't be many of them around that area!
Spotted! 2 4 door white R34's, one parked on nepean highway outside Toyota, the other a bit further down the road outside Lexus.
Also just saw the yellow R34 cruising along nepean highway near north road, had SAU stickers! :unsure:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
