spotted a silver r32 gts in hartwell around 5:45pm, just going under the train bridge, was following for a min or two.
wes***
spotted a white r34 on highbury rd around 6pm heading vermont sth direction, didnt catch the plates.
wes***
Hrmm might be me? I was on turning onto highbury road from springvale road at about 6:15p.m but didnt see a Stagea though :P
Are you the r34 that lives in that street off highbury road with the black hood? Always see it when I go for a run.
Nah not me, don't have a black hood just a white R34 with bronze TE37's.
But yeah i do live just off highbury road :D
nah, i was up at the bp near the new hungry jacks on blackburn rd.
the r34 was heading towards springy.
hear boostn0199 most nights coming home down robinson.
Hrmm might be me? I was on turning onto highbury road from springvale road at about 6:15p.m but didnt see a Stagea though :D
Where do you live? in robinson aswell?
Silver S2 r33 behind me in seaford maccas drive throw, ooked like it had sau stickers from wht i could see out of my mirrors when leaving spotted a grey 32 with a red p plate crossing franga dandy rd.
^fark havent seen her around in a while. she used to be committee didnt she?
yeah I've been busy :P I live in Werribee now..
I've seen plenty of peeps round Hoppers Crossing and Geelong recently but no SAU Stix.. well except for the white.. err 34? I beeped at when going past me the other week in Werribee with SAU Stix.. you live like 2 streets away from me. There's a black 32 or 33 that lives almost directly behind me too (I forget which).
Saw some guy in a.. 33? in Drysdale the other week... can't be many of them around that area!
Spotted! 2 4 door white R34's, one parked on nepean highway outside Toyota, the other a bit further down the road outside Lexus.
Also just saw the yellow R34 cruising along nepean highway near north road, had SAU stickers! :unsure:
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
