CR33M at princess last night doing laps and OMG200 also, was so many cops out last night out in force !
no kidding, came onto the highway off wellington road with a mate & first set of lights pulled up next to a highway patrol car...shat myself haha
also saw cr33m, a few 33 gtst's 4 door 34 & a silver 34R !
Spotted along springvale/princes hwy
Red 34 had gtr kit badges etc though pretty sure wasnt a gtr :/ plates RAMI07
Grey stagea plates MRNSN or something and behind it white 35 gtr plates NAFTA or similar
That was for sale on Firesport lol
R35 in grey on Maroondah Hwy in North Croydon about 8:15am this morning, GOZQLA or something like that.
i've seen that guy a few times. i drove up beside him and gave me a smile and nod. usually the r35 drivers i see just snob you lol
Last week was f**ked! Cops over every hill. Counted 7 between westal rd and warrigal. I hear someone got issued a fine by officer pettet that night. Don't know how game I'll be on the highway now. Might need to change to nepean
yeah heard pettet has moved out there now, pretty sure it was him that i pulled up next to at the lights, he tailed me for a bit & ran my plates then went & hid in some bushes with the speed camera haha
he bent me over my bonnet on new years day this year, tailed me all through knox city car park & then issued me a fine because my indicator clicked off when i was entering a car park, apparantly i "didnt indicate long enough to warn other drivers"....there was no one around :|
2 points & $120 fine, he loved every moment of it haha
ill be honest though, he's the best man for the job of prinny !
Edited by lindz34
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
    • Yes then it will turn on but I want the car features to work
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
