last night on burwood hwy around 8 I saw a yellow r34 with sau stickers and many other rear quarter window stickers while I was turning on to eastlink. Pretty sure the driver was looking at me
Twas me in Alvin's beast. Meant to post in here but forgot. Thought I'd give you a stare down instead of the usual Skyline snobbery :P
thanks, I do like a good stare down.
Spotted a white 33 with SAU stickers going down warragul rd at around midnight. Looked clean.
Sounds like me, did it have black rims? If so it was me. I saw heaps of skylines out tonight.
Could be, I think I remember you saying the same thing last time I spotted the same or similar car in the same area. I think it has had a rim change again perhaps.
I put it back on 17" Rays, 5 spoke, nice plain rim that looks similiar to stock wheels, used to be on gold 19s.
I think I also spotted you at a BP near Chadstone Shopping centre, back on the Friday 23rd Dec.
You met up with your friends and they had a black VY SS Commodore..?
Good memory, haha. the VY is just a six though, he did a nice job at mocking it up 4 years ago, regrets it now.
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
