OK Russ what are you up to???
Can't you guys stand still for a while at least?
Beer Baron I have always been the best customer here. Also as Toyota say, "We race we learn you win."
  • Replies 1.9k
Hey crew,
Just letting you know that I am in Perth and have found out we already have 42 people booked for the 5th of June. I think it is being capped at 50.
Get your scates on if you are interested and call me.
0412 574 010
unfortunately I've come across a spot of a cash-flow problem, and as a result my motorsport hobby is on hold :D and my track car is for sale (see link in sig) :bunny:
I don't know a cheaper way to get these kind of lap times - Wakefield 1:07.40, Mt Cotton 46.33 (under IPRA record), Conrod Supersprint 49.47
Not too late for someone to snap it up and enter Superlap...
Hey John what ya reckons will we beat the slot car. We just might have ya lol. :P
bummer on selling your little weapon harry. you are right under $20K to get those sort of times is one hell of a bargain. especially in a car that could be road registered as well. the best part is with relatively smally brakes and wheels and a fairly light car the tyre and brake bills wont send you broke! so it would be a cheap car to race as well as cheap to buy. i'm sure you wont have a problem finding a new home for it. :P if I had space and money it would be on my shortlist no doubt about it.
thanks guys. yep, 400hp and about 900kg does equal alot of smiles anytime you drive it.
kinda hoping it doesn't sell and hopefully I'll get to use it again by the end of the year. so many places I want to take this car and get some laptimes. If I get the job I applied for last week, the car will definitely be coming off the market.
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
