  • Replies 410
Posted Images
renewing beforehand might be a bit tight because CAMS are veeeery slow processing simple paperwork. but we can renew it on the day for you and give you a 21 day temp license
shweeeeet.. I was going to try and renew mine tomoz as it expired at the end of March ;) .... Il just wait till the day and bring my form already filled out :D
This isn't driver training :thumbsup:
There are no accredited instructors, and you are signing a waiver which is under a motorsport body (AASA)
Sorry Duncan...
Yep Spoke to Shannons for the last trackday I did and they pretty much said anything sanctioned by CAMS or another motorsport body is definately not covered.
It pretty much covers you when you attend an actual driving "school". Like luffy's thing.
Few questions:
1) Has my payment gone through?
2) How many spots are left? As I may have some other people interested in coming along.
3) Can the list on the 1st page be updated?
4) For people who have attended before; is it worth putting on the semis for this or will street tyres do?
5) Any news on accommodation yet?
Thanks
Few questions:
1) Has my payment gone through? Yes.
2) How many spots are left? As I may have some other people interested in coming along. So far I only have about 17 entry forms.
3) Can the list on the 1st page be updated? That is Steveo's Job :thumbsup:
4) For people who have attended before; is it worth putting on the semis for this or will street tyres do? Ask Chubbs or A31Deviat
5) Any news on accommodation yet? There's an accommodation thread in the NSW section.
Thanks
Raul!
I was on semi's and so was Ando - we were top 5 on the back track. about 2-3 seconds quicker than the others.
If you really are keen - semi's for back track - then streeters for the skid pan (dry) but I have used semi's at DECA on the skid pan and it still worked great, it depends if you want show or go :thumbsup:
OMFG!
HOW LONG DOES IT TAKE TO GET MY L2S License!?!?!?!?!?
CAMS are a bit slow at the moment, I sent my renewal in on the 20th of March and they only processed the payment last Friday. I am expecting to recieved it this week.
    • I'm normally copping my own abuse from neglecting my daily drivers. "Those suspension bushes will last a bit more", "Don't worry about the oil leak, just keep topping it up". The project cars I'm always doing things slowly on them as I'm wanting them to be done better, and neater, and nicer. Luckily I don't have to deal with 18 year old Matt's "Learning to wire" stuff in the project cars. And there's only one piece of wiring I'm displeased about in the Landcruiser, and it's about to be cut out... However, the box loads of parts that have been going through this place lately for the Landcruiser... Brake pads Brake Rotors Full handbrake overhaul Wheel Bearings Seals Swivel hubs Steering Boxes Half the suspension joints Shocks Air bags (Ones to go in the rear springs for towing) Water pump Timing kit Lower timing case Harmonic Balancer Radiator Lots of other little seals and shits Gas struts for the bonnet New power window switches And god knows what else I've forgotten... Ha ha ha I have my fingers crossed the pinion seals don't start leaking on the diffs, that the transfer case doesn't leak, and the gearbox input shaft doesn't leak, nor the rear main seal. As they're about the only seals I haven't replaced in the driveline! I'm seriously eyeing off buying new caliper rebuild kits front and rear brake calipers... I'll probably recheck all the valve clearances soon too, and hopefully, it should be all good and sweet to haul some long distance trips again!
    • Every time I pull my 3x gauges out of the console and see the crack-addict way that I did the wiring, and I just can't bring myself to tear it all apart and "make it nice", because it is currently working. In fact, the last time I was in there I probably made it worse.
    • The best part is when you own the car long enough that you look back and find your OWN ham fisted amateur shit!
    • The annoying part about neglect, is when you start to replace one thing, and find ten more broken things. Ham fisted monkey repairs you normally only find out about when trying to do something unrelated! Ha ha   Neglect you can kind of anticipate the huge costs to fix it all. Ham fistedness is normally a shock the first time your work on a new old car, as everything "looked" good before.
    • For DBA, check out their guide table here. https://dba.com.au/wp-content/uploads/2023/01/Direct_Replacement-Guide-2021.2.pdf   Additionally they have some other guides and info on how to make sure you choose the right pad.
