i worked at lemans wen if first opened at the new place. god its great fun fanging them around wif only u on the track . i gotta try and remember what i have to do again with clothes pegs to make them go a bit harder. hehehe
  • Replies 207
Ahhh but you see in Knox I can persuade TMU officers with an offering of cock, you all know they love it.
Yeah yeah ok I'm coming.
Yeah yeah, I used to live in rowville. Tried that without any luck =/
Ah well, they sent me a nice little EPA letter to apologise for interupting my evening. Or not...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
