RB26DETT or 2JZ
263 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
who really cares. this thread from back in 2008, and was dug up by some noob, so i don't think the OP is going to care anymore.
as for what is better, the engine in the supra is superior in quality to that of the GTR (and you will find that anyone with any decent mechanical knowledge will agree, even on this forum). also in stock form the supra isn't far behind the GTR in a drag race.
  • Replies 124
Posted Images
  • 1 year later...
lol 2j may be a better enginem but be f#*ked if I would drive a fat ugly supra. Esp since 99% of them on the streets are N/A and have been fast and the furious over done, making it the ricers 2nd weapom of choice behind hondas
A supra looks more sleek than an r34 gtr =\. But i do agree with the non turbo point. But twin turbos are in a different league.
still the same looking car. Not like a GTR and GTT where the supr model has phat guards and a stance like a BOSS. Supra make have a sleek look but GTR screams.....get out of my f**king way or i will destroy you....tough
ahahaha, and the interior looks like it's from the 1970s. they have the potential to look good, but they often end up looking like arse. a bit like a 33 4 door, LOL
just kidding, the 33 4 door doesn't have the potential to look good
Must...not....necrothread.....ahh, stuff it.
Supras look homo.
Therefore RBs win by default (unless you can find a manual Chaser).
/thread
What about the Aristo?
2J + rear seats + a boot?
I'll stick with my 20B, more factory power and torque then both of the formentioned... :whistling:
Edited by Hank Scorpio
I didn't think they came in Manuel?
So therefore a Supra TT would be on par with an R34 GTR?
This means the Supra TT is better value for money... $25,000 Vs $45,000
Is this right?
Interesting that a R34 Gtr can be acquired for $45k back in 08. It must have been quite a steal at that price... either that or they haven't gone down in value over the past couple of years, in regard to all the other flagship cars from Japan.
I do like the look of the R34 Gtr's in general, although they do tend to appear fairly lean and tall for an all-round performance orientated car. How Nissan managed to make them handle the way they do in relation to their form deserves some accreditation. Perhaps the same goes for the R35 and all prior models.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
