front lip is a do-luck item which is actually suposed to help with down force
side skirts are top secret items
every series 2 does ...
I'd love to know where people get their info from :thumbsup: ....
Ok for a start that is an Abflug front diffuser
found here:
http://abflug.jp/products/
...and secondly there is no such thing as a series 2 gtr lip as the series 2 one is the same as the series 1 lip. That is a series 3 gtr lip.
Anyone know where I can get Nismo 400R side skirts to suit R33GT-R??
I assume you mean genuine ones jack? If not copies can be found anywhere....try the usual suspects like just jap etc.
If you are after genuine....good luck! Once in a blue moon they come up on yahoo japan but I haven't seen a set for well over 6 months....
Yep, have checked all the usual suspects, they all have them to suit GTS-T's but non for GTR's.
Have been looking on yahoo aswell, no luck either. :thumbsup:
found here:
series 3 then, you know what i mean, as if there's any significant diff between 1 and 2 anyway, i refer to the later model as a series 2, sorry for any inconvienience / tears i may have caused
Edited by sic200
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
