One of my former R33's has now been sold on to another of my mates and he has plans to up the power a tad.
He's budgeting 2K and wants it to be safe. I'm asking you guys coz I haven't had a Turbo car since I sold the GTR a year ago and it's been even longer since I had the Series II R33, RB25DET with manual cog swapper.
It currently has the following power wise.
Complete turbo back exhaust
Pod filter in heat shielded custom airbox
Dual boost mode for 7psi standard.
My guess was to go something like the following - prices are guesses too.
Slidewiz type highflow turbo ~900?
Justjap style FMIC kit ~ 400?
SAFC + tune ~ 200 + 800ish?
Fuel reg/pump? no idea.
I know that's more than 2k but I assumed my prices would be wrong or that I was overcompensating parts wise.
Max power is not the issue, engine safety and drivability is.
I also considered scrapping the FMIC in favour of an R34 GT-T side mount but I was unsure of the max power these could push.
PowerFC is out of the question due to costs.
My guess for the above was a healthy 200-220rwkw's if fuel mods were also done.
Thoughts?
Cheers
Dan
https://www.sau.com.au/forums/topic/216771-2k-challenge-best-bang-for-buck/
Fuel Pump - $200
FMIC - $450 (or less from our traders i think)
S-AFC + Tune - $700 give or take
Clutch - 1k
Thats the 2350 spent, and thats over the budget with no more room for coil packs being in need of replacement (always a possibility)
I woudnt upgrade the turbo on a S-AFC only, full ECU or nothing is my view there.
And then i dont like the 'affordable' turbos... prefer my researched and proven ball bearing models
Thats my view, if it doesnt have the stock clutch then maybe spend it on a diff? Usually they let go early too and a single spinner is the pits
for the money i'd do things in order of reliability first up, i.e a good clutch, fuel pump etc, then later down the road when he's after more power, the previously mentioned mod's will come into affect and he can spend whatever he has saved up on actual power upgrade's...
my 2 cents
my list
2nd hand power fc
used jap exhaust
2nd hand blitz dual sol boost control
oh yeah :D You've listed 3 of my mods exactly :P
Whats he doing with the car? if track work
ugly as f**k jap 17x7.5-9 wheels all round (the uglier the cheaper)
235 45 17 RE55 SP2's
whiteline adjustable swaybars
That'll come to 2300 give or take, mainly dependent on how ugly/rubbish offset/damaged the rims are ;)
say hello to 5 seconds off your pb at wakefield (easily).
if you want 2k of power in an r33 with rubbish stock ecu:
second hand blitz ebc
china front mount kit
safc
tune
chuck in some sway bars for good measure. I can't help but look towards handling mods :(
Stock clutch is good for 200rwkw (just) if you are nice to it. be nice until you have another 700 or so for a clutch
Also think forward, if he wants to chase a bit more power later, dont skimp on some stuff now.
I mean if 200rwkw is all you want, no worries... but later if you decided to go further some things like the FMIC or turbo (if changed) might not be upto the task and resale poor etc
I should've been more specific about the car.
It has splitfire coilpacks already.
It has height adjustable Bilstien shocks with whiteline adjustable camber kits - I know coz I installed them when I had the car :banana: Already has dished 18's with 265's out back and 235's up front.
I sold the car with an Exedy heavy duty clutch, but I don't think it was installed or passed on to this owner so clutch could be an issue.
So you guys are not recommending a cheapy highflow? I'd of thought he'd make more power with a highflow and safc than the stock turbo and a powerFC, plus the stocker isn't gonna push more than 12-13 for very long, it's the original turbo on a car that's done close to 90k's mind you it's never been boosted beyond 7 while I had it or my mate after me and from what I know the current owner, another mate, hasn't boosted it either.
I was under the impression getting a PFC tuned was in the range of 1k, especially where we are - Albury/Wodonga region - though travel to Melb is not out of the question. That'd eat up the 2k pretty damn quick.
Plus I'm not sure if he plans to go further beyond this round of mods. Keep the ideas coming guys and I'll dig up some more info.
Cheers
Cheers
Ive quite sucessfully ran the base map on the power fc with some mixture correction (use injector tables). They run quite a good STD map its just a little rich. Did this on our STD turbo dyno winning GTR at SAU dyno day and made 287KW at the tyres with minimal knock. To prove a point i initialised the power fc and with six adjustments (each injector) made the same power. So no need to go for a full tune on a street car if you know what your doing.
Edited by DiRTgarage
I think thats quite risky...
You would...timing figures are quite conservative and fueling is excessive on the base map. Leaning off each injector is quite a safe method and we have double checked this method on a dyno with AFR meter and found it to be just fine.
a lot better than running a stock ecu and with boost levels up to 1 bar will be quite OK.
but...not a thing to tinker with if you are not confident on what you are doing.
this method is no more risky than running a STD ECU in your car using Aust. fuel
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
