Why whats she making now???
I dont know how much more i will get from my next tune. Should be a bit. :)
About 305awkws at 18psi im hoping that with 22-24psi and the cam gears played with 350-360awkws can be had but who knows this car never dose what its told. My exhaust is the main problem but i like to keep it quite now days.
  • Replies 344
Posted Images
"What are the new tyres you are putting on?"
I have gone for some more Toyo T1R's in 265/35ZR18. I run these on my GTR and they provide good grip especially in the wet with their open tread pattern. The only draw back is that they are noisy which simply means turning up the sterio.
Victory ....... how wide are your rims ? mine are 9 inch and I run 255's but I would like to run 265's. Do think the 9's would handle the 265's alright ?
Tim.
Sorry to butt in, I have 18 x 9's on my R32 with 265/35/18 & have no probs with fitment :P .
I'm sure you wouldnt either champ ;) .
I know that this has probably been asked before but why are we not showing the times from the back track in the afternoon?
I dont think that the morning times should be the bench mark because the track temp was cold and there was little grip especially for those people using semi slick tyres. There was also a lot of loose stones and dirt on the surface in the morning.
The grip level in the afternoon was substantially better because the track temp was higher and there was less crap on the road surface - therefore giving the drivers a better chance to utilise their driving skills knowing that the car was less likely to lose traction.
Perhaps an average from the morning and afternoon runs should be worked out and used as a comparison? :)
I run 265/35ZR18 on 18 x 9 rims and they fit perfectly.
The only problem is that the OD is 644 mm and is a fraction small when the correct OD is 650. This means your actual speed is about 5km less that what your speedo shows. This is what most car companies do so that you are just under the speed limit.
I was running 245/40ZR18 on 18 x8 with an OD of 651 which gave me the exact speed on the speedo in both the GTR and GTS-T. I was going to go for 275/35ZR18 to get back to an OD of 649 but Toyo only had 2 in the country and were hoping to get in another 6 in July. Even though they would have been the exact tyre for the car if they are that rare then if you stuffed one it would be a real pain to try and replace it.
Not a bad figger to go for.
What cams are in it?
Also i use 255/40zr/17
Not enough grip for my monstor on its run in tune :) Cant wait to wind up the boost. :P
Edited by BNR32t
evil weevil, Chris' camera is a GoPro, same as mine.
www.goprocamera.com then go to the Motorsports Hero.
I got mine from http://www.soloperformance.com/ in the USA as well as a CruiseCam headrest mount for about 310AUD all told.
User NISMO also has one which he got locally.
Here is some video I took from Wakefield. I had the sound on the wrong setting for in-car though. And the footage is much smoother when you use the included suction cup. And yes, I damn near **** myself at the end of the video hahaha
Me making an area of myself
ooh pick me pick me!! :P yeah i'm interested ;)
I'm have the costs for the actual products. I just need to find out costing of freight from them to me and then postage from me to you which will just be those post packs either exp or stnd.
Hopefully It will be cheap cheap.
As soon as I find out I will post up and see if we can get it happening.
can that camera be used as a normal video camera, like hand held? if so i might have to get one as well!
I'm not sure but I will look into it.
There is a guy doing them in TAS section but I'm getting them a lot cheaper.
lol made an "area" of myself.. damn, nice price VZSS!
They CAN be used as a hand held camera, however they are so small that you might find you aren't really pointing in the direct you think they are. I wouldn't rely on them for that kind of use. CeJay I can show you mine if you like. I'll bring it the next Friday I'm out.
One really important thing is that this camera will NOT pickup any footage whatsoever (ie nada, zip, zero) at night time. I went for a drive at night and I could only JUST make out the halo from streetlights, and nothing else. And it BARELY picks up any footage indoors during the day, or at night with the room's lights on (ie the footage is so dark you can't make anything out). Even when I faced this thing towards a desk lamp, it is VERY poor quality. It really needs UV/daylight to work properly.. go figure. I was hoping to use it for night time cruise footage, but it is useless for that. I was really disappointed about this part, but I mostly bought it for analysing laps and stuff during the day, so it's alright for me.
The other thing is, Wakefield Park (and probably many other tracks in AU) will not let you use this camera with the including suction cup mount. If you want to use it on the track, you'll need to get a proper bolt on fixture, like the "Cruise Cam" i mentioned in an earlier post.
Other than that, it's great - you can see what footage is captures in it's ideal conditions. Oh, and the other thing: it chews batteries like a mofo. Lithium or BUST!
Edited by sl33py
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
