further back in here it says that the V66 has 6
cheers mate i lost track there is that many references to the v44, 66 and 88 i dont know whats what lol, i think the vipec site needs to add a v66 and the specs to save all the questions :thumbsup:
im gonna be keen for one at $1500 its perfect price, just hope they are easy for most tuners as alot of tuners here are not fans of the autronic and im assuming this is a similiar design. When is the software program gonna be on the website i would love to check it out?
  • Replies 895
hmm it seems we have to buy them from local tune shops, not direct which puts me off a bit.... hopefully we can sort somehting out as im keen to get my hands on one to test and play with and find a decent equiv for haltec etc.
Let me know if you get hold of 1 trent. now that you have your shop open, id love to come round and finally meet ya. would be good to see the setup you have there. been hearin good things.
Would like to know what you think of this ecu. possibily replace the pfc in my car when ive got it up and running again
Whats everybodies opinion on the V66 Compared to th Haltech E11V2???
Got a little bit of news on the V66...yes its based on the V44 but is a special one off item specifically designed for the Skyline and features direct fire ignition. I was worried it might be a wasted spark set-up but no its direct fire. Still a couple of weeks before i get some in stock...illl let you know when its here.
I have just recently been searching for an upgrade for my PFC and came across this thread. The spec of the vi-pec ecu's looks very impressive, especially considering the price of $1500. I have a few questions about the V66 plug in ecu board for the GTR:
  • On the spec list it states the ecu can be used with MAF sensor. Can it be used with upgrade MAF's such as Nismo and Z32? I was thinking of running the ecu with stock MAF's until I decide whether or not to run upgrade MAF's or MAP sensor.
  • Will the V66 plug in board have the same of number inputs and outputs as the V88 standalone unit and if so how do you wire additional inputs into the ecu as it will be using the factory loom? Things such air intake temp and wideband lambda signal?
  • For the active knock control will the unit use the factory knock sensors or will it need vi-pecs own knock sensors to be fitted to the engine before it can take readings?
As a bit of back ground info I have an R32 GTR with GT2860 turbos and have uprated the fuel system which now includes Tomei 280L pump and Sard 700cc injectors. Ideally I would really like a system which has a base map for my current set up.
For any east coasters these are available NOW through Godzilla Motorsport contact www.godzillamotorsport.com or you can pm me on here for details. Units do not have a base map loaded on them so they are not a turn key option. Ordering through Godzilla will get you a preloaded base map so it is a plug in turn key item.
Post Removed.
See post here for why.
Mark at Godzilla Motorsport in QLD has installed a couple in GTR's and one in a GTS-t.He is amazed at how smoothly the cars now drive with the new units installed. The off throttle return to idle is also far superior than anything he has experienced with a skyline before.
Truely a world class product.
ya i was having all kinds of idle issues, granted some of that has to do with my q45 TB with the monstrosity of a plenum i have rigged up to it, but the vipec overcame all that and never stalls regardless.
Great results on the dyno, but i was more impressed with the ease and response we had road tuning. very responsive interfacing and fun to work through. The launch control paired with using traction control at rev intervals and my first crack at this no lift shift (or flatshift) business has made driving an absolute delight all over again
Edited by Paradis v.1
Yeah im itching to get the fully optioned V88 into our drag car for testing. Especially the anti-lag launch and the flat-shift. Sick of having to feather the throttle after the burnout to stop the car stalling too as the Power FC hated returning to idle.
Edited by DiRTgarage
Just been looking through the Vi-pec site...
It looks as if the plug in ECUs are just the board, does it come with a case? asking this because I already have a PFC and dont have a factory ECU case to use for the new board.
Regards
Andrew
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
