  • Replies 41
Mine stock pulled: 160kwrw mark
With Cat back : 175kwrw
So full turbo back should expect up to 180kwrw im assuming? But then i read this thing about how an extra dump pipe could give loss of power without tune.
Also, what i'd like to know is which shops dyno run reads higher or lower.
Apparently UAS claims their dyno reads lower than others, and thats where i did my dyno run.
Belgarage, i heard reads accurately lower than others as well.
CRD, apparently reads too much higher than other places that ppl coming from CRD to dyno at other places get dissapointed with their runs.
Are there any more opinions on which place is accurate?
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3860050
ah yer i agree hitman is the best for tuning but regarding power runs does hitman show generally accurate kw?
So what i mean is, after hitman have tuned ur car, have you actually went elsewhere to dyno run and see whether it is actually 60+ kw?
Edited by R33Turbo
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3860410
And i suppose John "Pelican" at unique fed you that dribble...ive heard him say it to customers time and time again about so called "Croydon Watts"...heres some proof
My car
CRD 439kw...the next day at Autosalon Sydney 437kw
CRD 467kw (at night with cold air) the next day at Autosalon Newcastle 455kw (the heat of the day in an auditorium with not much fresh air)
CRD 486kw...the next day at Autosalon final battle Sydney 487kw then the next day took a little bit of fuel out of it to push it over 500kw with 502.4kw.
Both dyno's are of a different make from Croydon (Dynodynamics) and Autosalon (Mainline dynolog), and the dyno in Newcastle is a different Mainline Dynolog to the one used in Sydney.
They are so accurate because they are used by skilled operators with more years of experience than most people on here have been alive.
So please don't post hearsay dribble you get fed from other workshops.
And just for the record I no longer have any affiliation with Croydon Racing.
Edited by DiRTgarage
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3860411
lol dirtgarage, for the record i don't take john's word and where ive heard this is from a mate (customer of CRD owns a WRX) who dyno ran and pulled 180kw then went to Autotek and pulled 150kw. And now i don't know how the weather was like but it shouldn't of made more than 10kw difference if it were to be accurate. And please don't tell me autotek is just inaccurately low, cuz then how would they get business for tuning? lol
anywayz no offence to CRD affiliates like youself
P.S. im only giving my opinion here from my experience and my friends experience, and please don't take anything offensive or you might break my engine when i go to u to rebuild it :P
Edited by R33Turbo
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3860436
P.S. im only giving my opinion here from my experience and my friends experience, and please don't take anything personally or offensive or you might break my engine when i go to u to rebuild it :P
no offence...just thought id post up some reality. Ive heard John Pelican dribble that line more times than Ive cared to remember. Autotek may have their dyno set differently...both CRD and Autosalon use industry standard locked perameters (shootout) so that figures all over Aust. can be directly compared. It is extremely accurate, as most competitors will agree and all CRD's cars have made nearly identical power at Autosalon whether it be in Adelaide, Melbourne, Brisbane, Gold Coast, Sydney or Newcastle. its no co-incidence, its a fact than can be backed up numerous times with concrete evidence witnessed in front of thousands of onlookers.
Again im no longer affiliated with CRD so i gain no benefit from sharing some real results.
You engine is in safe hands at Red R...heck id even build one for Sydneykid if i had too. :D
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3860477
You engine is in safe hands at Red R...heck id even build one for Sydneykid if i had too. :)
lol npz ill be there in near future.
Just a question though, about UAS in ur personal opinion are they accurate? apparently Tim from UAS says it reads generally lower especially on cold weather and not hot (due to some adjustments made for weather changes). What is ur opinion on this?
I only ask cuz u said on a cold weather ur dyno kw was better than it was on a hot weather.
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3861203
Basically no dynos are directly comparable, as Paul said even in shootout mode you can accidently or deliberately get differences in temperatures and settings that give different results.
No doubt some workshops are a little harsh in the readings they give customers before they work on the car, and a little generous afterwards to make it look like they have done more than they have. This is particularly true when people have had their cars "tuned" when they have a stock, untuneable computer....
If you really want an accurate place to compare power output, take it to the drag strip and post up you MPH. No settings to play around with there, just a stop watch
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3861228
i agree 100%. :):P;)
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3861524
oh alright, the thing is i could never understand how much power a car made by looking at mph.
For example, mine in my sig how would u determine that?
Edited by R33Turbo
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3861581
Unfortunately I'm not one of those people lol. But 100mph seems a bit slow for a 13.7? Ask in the drag section they will sort you out.
easy...just use a calculator...like this...
http://www.eldemoniorojo.com/calculator.htm
https://www.sau.com.au/forums/topic/218766-dyno-in-sydney/#findComment-3861716
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
