Hi Guys.
I have a Stagea RS-Four V with 4WD, it have the RB25DET engine, and i want to make more then 800 hp.
There is a lot of strange rules in Denmark, i am not allowed to tune my Engine, only 20%.
Then i found out, i can buy a RB30 blok, and put my RB25DET top on it, to cheat the system here in Denmark.
I will then buy a 3.4L strokerkit, with help from e good friend, he will port my RB25 top for better flow, and put bigger valves in.
I know i need a lot of tuningsparts, and this will be very expensive, but thats okay.
Right now i just want to know, what is the most importend parts to change in the engine, to make 800+ hp.
I placed a order in a US company, looking for these parts, what more do i need.!!
ARP Pro Series Main Studs GTR RB26DETT ARP 2000
ARP Head Studs RB20/25 DET head stud kit
Tomie Metal Head Gaskets RB25DE(T) 88.0-1.2mm
Tomie Valve Springs R33 RB25DE(T) A-TYPE
Tomie Pro Cams, lift.!!!!!
Tomie Timing Belts RB26/RB25/RB20
Tomie Adjustable Cam Gears Set RB20/25/26
Stroker Kits 86.5 BNR32/BCNR33/BNR34 .!!!!
Nismo Oil pump.
Nismo Water pump.
Bearings.!!!!
I am not sure what to do about the Turbo, a single-setup with a HKS SPL51R Kai, or 2 smaller turbos in Twin setup.!!
I will use the car for quartmailes, and show, and then drive in it every day.
Hope you guys can advice me make these 800+ hp.
Picture of my car attached.
Edited by Stagea Denmark
i'd budget 50k+ easy and good luck with the gearbox with 800hp, ppg box ($15 000) or holinger box ($20 000+) is one part u will need and trust me i have a dogbox and its not a daily driver gearbox, i think u will need to upgrade every single driveline part and engine part to do this and i dont think u will ever get a 800hp daily driver, little own one thats reliable.
have u ever been in a 800hp skyline?
i dont think comparing a 500hp engine to a 800hp is even close either, its about 3 times the dollars and parts, and prepare for regular rebuilds if u are thinking of using 800hp everyday. The car will be slow on the street unless your doing 120kmh+, i have 600hp and the lag isnt ideal at all for a street car, plenty of 500hp cars will beat me if im not in the right gear and rpm range.
i thought the same as u when i built mine that 600hp could be a daily driver car and it aint ideal. I think the only thing a 800hp car is good for is dyno and thats it.
im assuming u mean 800awhp as well, or are u talking 800hp at the engine?
i also replied in your other thread with more info
if this doesnt phase you then good luck :D also your stagea is the hottest one ive ever seen in my life :P
Edited by unique1
ARP Pro Series Main Studs GTR RB26DETT ARP 2000 Wont fit rb30 bottom end without machining
ARP Head Studs RB20/25 DET head stud kit Would recommend upgrading to rb26 items
Tomie Metal Head Gaskets RB25DE(T) 88.0-1.2mm Really need to assemble engine before ordering this to determine final compression ratio
Tomie Valve Springs R33 RB25DE(T) A-TYPE sorry wont cut it
Tomie Timing Belts RB26/RB25/RB20 Wont fit
Stroker Kits 86.5 BNR32/BCNR33/BNR34 .!!!! Will be going backwards, should look into spoolups 3.4 stroker
Nismo Oil pump. Marginal if your going to go over 7000
Nismo Water pump. Not needed or recommended
Bearings.!!!! ACL race series
There are heaps of other parts you will need, i would recommend reading "the thread" before you embark on this to gain a full understanding of what you are undertaking. If you need a block sent over, ive done one to canada, so denmark shouldnt be a problem.
Thanks all.
Unique1 > I have a 500 hp stag aswell, at 1,35 bars boost, the red one i my profil, i know what 500 hp is, had a 800 hp Supra, but i never had a 4WD with that hp, and thats my goal now, money is not the main thing, it is expensive to play with the big guys, i know.
Duncan > thanks, i will have this i my mind. ;-)
fob33 > thanks, i love them both.
Adriano > Your right, my fist plan was a 2,8L strokerkit on the std. RB25DET engine, these parts was for that.
Back to bussines, what the best thing to do, go for a small liter-effekt, a screaming and wild engine who makes 10.000 rpm, or a 3,4 liters with lag and 8500 rpm, both with 800+ hp.!!
OBS. Pictures of my red 500 hp Stag attached, and the engine.
There is a chap in NZ who has a 800hp Stagea using an RB26DETT converted to single T04Z, it struggles to go much faster than around mid 11s on the strip though I figure the 2.6 is far too small for the heavy thing.
if u are talking 800hp at the engine then its a different story though gearbox options are still the main issue for drivability.
my stagea makes 560hp at wheels (t04z on only 18psi and pump fuel) and has ran 11.33 at 125mph, thats full weight, 2 sunroofs and full tank of fuel (around 1720kg + driver) definately got more in it down the track at same power as i had some misfiring issues, the weight doesnt help but u just need more power. Im looking to run a 10 before i give up on the stagea :) race fuel and 25psi+ should make around the 640-650hp at wheels mark.
if he can only manage mid 11s on 650hp at wheels the dyno is wayyy out or he needs to abuse the car abit more down the strip lol, i assume this is Simon (Pure Methaphetamachine) or whatever his username is?
Edited by unique1
Yeah its Psymin - and the times it has run are not that flash at all for the power its made, hub dynos read higher than Dyno Dynamics BUT that is still slow for that power on that dyno. Is yours still a 2.6?
fair enough, mine is a Jun 2.7L bottom end, i find it goes well, im sure the added weight over a gtr is killing my times though but i like to have something different :spank:
I have asked a good friend to help me tune my Stag, his name i Nicolas Kiesa (Former Formula 1 driver), he tune a lot on R34 V-Spec II, i know he got a lot of help from at guy in Australia, they are both member of http://www.exvitermini.com/, Kiesa's homepage, awesome R34. http://www.kismo.dk
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
