Hi guys.
I need help installing one of the manual boost controllers onto my r32 gtst.
I cant for the life of me find where to insert it tho i have found plenty opf manuals for the r33, nothing for my 32 can i find.
I really need pics so if anyone has a pic of where they put theirs on their 32 stocky then plz let me know.
Thanks in Advance.
woul dlike to know this too :banana:
thanks
I'm pretty sure its the same for a 32 but this is what i did in simplified form.
- Locate solenoid. Take off the top hose and put a bolt in it to block it off and cable tie to secure.
- The hose on the bottom of the solenoid should be connectod to a T piece.
- Remove the T-Piece.
- ur boost controller will replace this.
- As in the pics of Turbotech...follow instructions...bottom barb to turbo..side barb to actuator.
MAKE SURE YOU UNPLUG THE SOLENOID.
Hope this helps!
Searched for like 2 hours and nothing on the rb20's only 25's.
I found the wastegate and there is a line coming from the bottom of it and im guessing this is the line i need to put it on.
I dont think us rb20's have this solenoid and stock t piece so im guessing i have to cut this line and put it in.
If i get a confirmation that its the correct line ill put a pic so others can see for the rb20's
No offence, but I honestly think, if you cant figure out how to install a bleeder to your import by understanding the dynamics, or find the answer on the interweb, you should be taking it to a mechanic.
  • 3 weeks later...
Come on guys im sure you can be a little more helpful, they're obviously new to this. I had no idea either when i first started, and i didn't bother asking questions like this coz i knew this was exactly the type of answer i would receive.
anyway, 32s don't have a std boost solenoid so don't worry about that
If you can see the turbo it's fairly easy,
theres a hose coming off the turbo housing to the wastegate actuator, cut the hose and plumb the controller into it. you might need to get a longer hose. I cant remember which way it's supposed to face so check your instructions but as far as i remember, the nipple opposite the big screw is supposed to face the wastegate actuator and the other horizontal nipple goes to the turbo housing
r32woohoo is spot on - r32 has a pneumatic wastegate actuator and it alone controls the max. boost pressure & when the wastegate opens.
the controller goes between the wastegate actuator nipple and the turbo compressor housing nipple.
he is also spot on the assessment of some ppl's attitude on this forum - we've gotta start somewhere, we've all started out as a newbie.
it helps if you understand how it all works but i really don't think we need the answers like "if you can't understand/do this, take it to the mechanic". some ppl DIY to save money, others do it to understand and learn. this is not really personal to you GeeTR, just an observation and a suggestion.
cheers
sam
Edited by sonoramicommando
cheers guys.
i knew where the hose was and what i had to do, just wasnt sure if the 32 had a solenoid like the 33 does.
but thanks for the feed back. it does clarify things when someone that knows exactly what they are doing (not people like myself that sorta no what to do) pass information on to others so they now know what they are doing
cheers again
drew
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
