Sorry for reviving old thread but in search of building a responsive setup too, bought the car with GT2860-5 already which i find laggy but don't want to go to the hassle of replacing the turbo's with say a -7 or -9, recently bought Tomei cam gears hoping to get a tune soon with those and get abit more torque low end, car currently makes 262KW, not searching for power atm, response is my main goal for now, any suggestions?
Mods are:
Arc airbox with Stock AFM
Power FC
GT2860-5
700cc injectors
HKS exhaust
Tomei Cam gears
Thanks
Cam gears and a good tune might net you ~300rpm but that'll be best case scenario really at the end of the day.
Overall the only two 'simple' options to improve the response is capacity or downsizing turbos.
Thanks for the reply, will put up a post soon to see if someone wants to swap -5's for -9 or -7's with cash adjustment depending on condition of my turbo's as i don't know what condition they are in, obviously not expecting brand new -7's or -9's haha.
Keep in mind that was with stock cams too with -9's.
My tomei type b's I'm running now were a bit of a disappointment down low for off idle to 3000 rpm response.
I was surprised how good the stock cams are!
  • 3 weeks later...
Got advised there won't be much difference if i swapped out the -5's for -7 or -9, will just waste my money since i already have the -5's in, so adding tomei cam gears, tomei poncams, arp head studs, and valve springs, hopefully after a tune it will sharpen response abit more than it is now :)
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
