Sorry for reviving old thread but in search of building a responsive setup too, bought the car with GT2860-5 already which i find laggy but don't want to go to the hassle of replacing the turbo's with say a -7 or -9, recently bought Tomei cam gears hoping to get a tune soon with those and get abit more torque low end, car currently makes 262KW, not searching for power atm, response is my main goal for now, any suggestions?
Mods are:
Arc airbox with Stock AFM
Power FC
GT2860-5
700cc injectors
HKS exhaust
Tomei Cam gears
Thanks
Cam gears and a good tune might net you ~300rpm but that'll be best case scenario really at the end of the day.
Overall the only two 'simple' options to improve the response is capacity or downsizing turbos.
Thanks for the reply, will put up a post soon to see if someone wants to swap -5's for -9 or -7's with cash adjustment depending on condition of my turbo's as i don't know what condition they are in, obviously not expecting brand new -7's or -9's haha.
Keep in mind that was with stock cams too with -9's.
My tomei type b's I'm running now were a bit of a disappointment down low for off idle to 3000 rpm response.
I was surprised how good the stock cams are!
  • 3 weeks later...
Got advised there won't be much difference if i swapped out the -5's for -7 or -9, will just waste my money since i already have the -5's in, so adding tomei cam gears, tomei poncams, arp head studs, and valve springs, hopefully after a tune it will sharpen response abit more than it is now :)
    • I've got a 2011 J50 that I imported six years ago. The unmodified factory AV system date and time has always been correct ( Japanese timezone of course ) up until last month. About two weeks ago, at engine start, the system wished me a happy new year ( in Japanese of course ). I can't think of anything that would make the system think that the date had changed, unless the GPS component has failed/reset somehow ? I checked the GPS reception in the system settings, and it can still see the satellites. Has any other J50 owner had this happen ?  It's no biggie, just annoying that it tells me the wrong date anytime I start the engine. 😅
    • Love following your adventures on IG, hopefully if you're still around in Japan when we visit again wouldn't mind going for a few beers with you (that's if you're keen on hearing how I hate Nissans).
