time has come to do my timing belt, what i wanna know is it worth spending a bit more and getting a decent one (gates?) or is somthing like a dayco or equivelent ok if car is not making huge power? planning on fitting adj cam gear also if that makes any difference?
cheers all
brett
if you aren't running massive revs and heavier valve springs there's no real need for anything other than a standard replacement belt. but do it right and get a kit with pulleys and seals (crank and camshafts) as well - seals are cheap and quick to replace, and tensioner and/or idler pulleys are insurance - if a bearing fails you may as well have not replaced the belt...
I agree, change everything else while your there if its never been done before
i personally would never use a gates belt again.
Cough up with your bad experience!
Apart from them being noisy buggers hah >_<
I'm not sure i would be comfortable with a OEM belt, huge valve seat pressures, steep ramps and 9k rpm though.
stick with a genuine nissan belt.
cant go wrong.
Yeah i'd like to hear this story aswell since i just bought a gates timing belt kit and fitting it this week >_<
i found that the fancy blue stuff on the outside of the belt starts delaminating and sticking to the brand new idler and tensioner. this then created a ruff surface for the belt to run on and inturn caused EXESSIVE amounts of noise.
put a nissan belt on and its been whispper quite ever since.
sweet as, any recomendations on where to purchase all the bits and pieces for reasonable price? also going to do water pump at same time, good idea yeah?
thanks all
bretto
nothing wrong with the nissan ones that i can see. every gates belt I've used has been noisier than oem, even when tensioned carefully. dangerman4 I've never see the blue come off on the pulleys, and I get to check mine pretty regularly. are you sure nothing got onto the belt?
have uesd both
it was reasonably clean inside the timing cover so dont think ant thing got on it
and did not have any adverse effects
but i have seen the blue come off
OEM Nissan FTW. Never ever had a problem with one.
But Aftermarket belts? (Blue ones in particular) well now thats a whole other story.....
Edited by RPMGTR
have uesd both
a picture says 1000 words.....
thats the stuff i was talking about. noisy as all hell.
genuine nissan ftw
what sort of noise was it?
mine has a bearing noise since i fitted a tomei belt only when idle drops down, sounds similar to a water pump noise but i changed that so thinking its the idler bearing!
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
    • Hmm not really, I'd say its race car life or modified car life when you make 3 or 4 times the power Nissan designed the car for lol.
    • I'll let others with more breakage chime in, but I can't think of anyone who had a problem with the standard centre plate before they had a problem with the standard gears - the plate generally just gets replaced for safety when the gearset is upgraded. As for the gearsets, its not like they are OK at 600Nm and break at 601. Their longevity is a combination of how much torque you are making and how gentle you are on shifts (or not).
