hey guys, do you have any pics of the water to air set-up?
we ran the PWR barrel cooler in the drag car for a while. took a bit of stuffing around to get it to work. ended up replacing the plumbing from -8 an fittings to radiator size piping to achieve enough flow to cool properly.
we had a 20litre tank in the car which we would pack full of ice water and pump it with a davies craig electric water pump. we were able to keep air temps down to 40deg at the end of the run, but being a total loss system as in having no radiator to cool the water once it had passed through, we had to change the water every pass. the water was luke warm when i would drop it, its amazing how hot the intake charge must be.
actually we are expecting to keep the intake air to within 10o of ambient even with 30+ psi which is the real benefit. but you are right it is more complex, I'd hate to do it in a roadie.
anyway, we are going to give it a go, if we get everything right first shot with this car it will be an absolute fcuking miracle. its really about trying out different ideas as much as anything after so long of only being able to race standard cars :)
There's absolutely nothing wrong with a front mount Air/Air intercooler. I have them on my roadie and have run them on my sports sedan/targa car in factory form as the rules state.
The big problem with them is heat soak. Anyone running a power fc with a hand controller can see air temp, and while they start great, after 5 or 10 minutes of hard driving on even a 20 degree day will easily see air temps of 65 degrees or more. This does drastically affect performance. You can feel it more than measure it. The car always feels more punchy after a lap or 2 first thing in the morning. After that it seems to settle in. Take your car out on a cold night and it alwasy seems more vibrant. This is what we hope to acheive all the time with the water/air.
This first intercooler is on the heavy side. Much more so than it needs to be. the tanks are cast aluminimum which looks to be about 4 mm thick. As a proof of concept, the price was right, and the construction is sturdy. If it all works well, we can look at making our own using a gtst (or stagea as it looks like there will be one lying around!) stock intercooler and building the water jacket around it. For now, we'll just have to pass on the extra bacon and egg mcmuffin on the morning!
This thread adds alot to my "To do list" i do really like the idea of water to air but having a light as f**k Arc cooler in my car i dont think i will be heading down that path.
i will be interested like alot of people to see how well it works tho! i was always going to put a Pwr Barrel system into my gtir, in place of the famous top mount Interheater.
i do however need an airbox made up tho moving the power steering reservoir and a few other things needs to be done!
P.s. never ever ever get involved in doing a group buy!! Argggggggghhhhhhhhhhh!
Stuart. No pics yet other than the cooler itself which is back a couple of posts. We are going to mount it where the battery and radiator resevoir usually are. The radiator for the cooler will be mounted in the rear bumper where the number plate usually goes. This should get enough air flow on it's own, but we're going to add some panels underneath once we figure out the best way to do it and this will drive air through it even more.
The davies craig pumps are overkill. There's no need for this to be a heavily pressurised system. We need the flow to be pretty slow for the radiator to work properly. I would bet that even with the relatively short time the your drag car was running the water/air, for the 10-20 seconds sitting on the line and running the 1/4, it still burned through some of your 20L very quickly. We need it to move much slower so that the radiator has time to work.
yeh, totally different system as ours was total loss, but we found volume of water to be the issue, not so much pressure. the small lines and pump could not flow enough water around the core.
our air tems were 15-20deg lower with this system than a air to air. but we didnt push the system for long time periods. it will be interesting to see how it goes after 5 or so laps.
A little research and I have found that the optimum flow is somewhere around 30 to 40 L a minute. The davies craig flow 80L a minute. Doesn't mean they won't work, as they can be reduced by dropping the voltage, just means they are overkill for the application. By all reports a very good pump though.
At full noise the DC would empty your 20L tank in 15 seconds.
We're going to start by using the 1/2 HICAS lines and see how it goes. The fittings on the radiator are 1/2 so wont be any more restrictive. Don't know if they will be ok, but there's no loss in trying them. We'll hook it up and measure the flow and see if we get 30L a minute.
If you grabbed that ARC off Tony then i will pay you what you paid +$50 for it :) Then you can get your water to air :rofl:
If you grabbed that ARC off Tony then i will pay you what you paid +$50 for it :P Then you can get your water to air :)
This one? Its sold :)
http://www.skylinesaustralia.com/forums/in...t&p=4088653
There's another one for sale, just came up:
http://www.skylinesaustralia.com/forums/in...t&p=4127388
so umm... sounds like you guys dont watch much wrc & arc stuff !:P
how does 20 degree's and sometimes less sound for air intake temps and thats on 35 degree ambient days also that was a few years ago!
i was lucky enough to go for a drive in a world rally hyundai with kenneth errickson a few years ago (when marcus gronholm was king in the 206) and you should have seen the lauch control , over 40 psi on launch without clutch load!
they are getting crazy results with air temps!
good to hear, we will run intake and plenum air temps to see if it was worth the trouble or not :P
that hyundai would have been very interesting to sit in too. 40psi thats almost as much as we are going to run thru those poor china turbos we have for this car
Giant, not saying that you are wrong, I'm sure they are able to use Air/Air efficiently, but rally is very different to track, and the RB26 is very different to a 2L 4 cylinder.
I never had any air intake temperature problems with the standard intercooler at Targa, nothing like 20 degrees, but it did stay around 45 degrees. The air's colder, it's always fresh and not someone else's exhaust, and more importantly, your revs stay lower most of the time. In the still air of the track where you spend most of your time above 6000 rpm, it's just not possible to keep the temperature down for long with an air/air. Have a look at the Gibson GTR and see what they had to do to try and keep the heat down.
No guarantees with the water/air, but there's no way an air/air will work on a GTR on the track and keep it down near ambient.
also in rallying they are allowed to use water sprayers on the intercooler, where's as your not allowed on track.
but most of it comes from water/methanol injection into the intake track under high pressure, done correctly in can actually freeze at the impeller tip!! :) from the airspeed when the mist travels from the centre of the impeller to the outside.
The water/methanol sounds interesting. I didn't want to start an argument, but I was very skeptical about a less than ambient temperature on a straight air/air intercooler. Just couldn't get my head around how it was even possible.
A lot of these total loss or injection type systems bear a bit of looking at as they have a real possibilty with what this car is being used for. Supersprints, hillclimbs, etc all have short spurts of running. A decent cooler set up is important for going round and round, but something that cools below ambient would be interesting, even if it only lasted one lap.
As requested........ let me know if you want it, i can possibly ask my mate if he'd fix it too if your interested.
there is no lip
and you can have the spiders too!
Edited by Angus Smart
What about that Gay intercooler,,,come on boys whats so bad about a normal one????
its not an intercooler mate, its a minature particle collider. hope it doesnt cause a black hole when we turn it on
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
