I had a Rb25DET motor from a 97 R33 GTS-T. I had it for sale for ages(3 or 4 months). perfect motor. Finally sold it for $1500 complete with loom, Turbo. gave honest description on the ads
My mate bought a 96 GTS-T which had 1 cylinder was down on compression. He took the motor out and put a used piston in, new headgasket degreased the motor
and then put it up for sale as fully rebuilt with rb26 rods, ACL bearings, N1 Pump etc etc etc. I was horrified.(And I never use that word) He said that there was to many rb25s for sale at the moment so he had to make his stand out abit. He got $2200 within a week (No Turbo)
shit like this pisses me off even if he is a mate.
Put me off buying used parts that have claims of being "rebuilt" What do you guys think
Edited by Brokenz
https://www.sau.com.au/forums/topic/222318-people-who-lie-on-their-ads/
Right.. Name and shame.. Some poor sucker has a Rb25 with standard rods.. Saying that sounds like alot of stories ive heard about mechanics nicking your parts and saying they got installed old parts disposed of.. hmm
f*kin rorting dog... why cant people be honest, same thing happend to me
bought a rb30 2years ago, told me it was original turbo block blah blah blah, my intentions were to pull it down anyways and do a big rebuild which i did..
but when i found out it was a ser2 na block, it just made the back of my neck burn a bit and i felt very betrayed..
2months later i found out it was na, the old owner got his na piston threw his front windscreen, then the other pistons threw the other windscreens...
jus be f*king honest..
this is one area where paper work doesnt go amiss, ask for reciepts when purchasing "rebuilt" engines.
signs of a rebuilt engine"recent" is the ever present gasket glue around the sump and main seal, and water pump housing.
in areas the head gasket protrudes from under the head, and from memory you can see the head gasket part number at the front right...
undo the oil cap and have a look inside, stick ya finger in there and run it around, even if the engine has been used since its rebuild, if the job has been done properly there wont be any crap on the underside of the cam covers.
Edited by nizmonut
good stuff! honesty is quite rare now days. I've had people crack the shits with me cause I ask too many questions or pics when I'm about to buy something.
lol think thats bad i bought a RB25 with no dip stick....and the owner still thinks hes in the right and thinks he told me about the no dip stick ;) if he told me i woudln't of bought he also told me its rebuilt blah blah blah i danno if its true but hte motor hasn't skipped a beat touch wood hehehe but yeah liars just makes me want to throw some pistsons too :)
yes i often wonder about many of these so called built engines you see in cars at auto salon and in magazines...They can bs all they like about whats inside and nobody will ever know
Yep. My engine has sick LS1 internals that are custom laser cut to fit into my reinforced block, and I've cut up 2 sets of S2000 cams so my car has VTEC too.
Don't even start me on the turbos that came off a Veyron.....
yep, very simple. no receipts = no rebuild. just another fantasy. your friend is a tool and there will be some nasty karma headed his way soon. no matter how clever he thinks he is people will soon cotton on to the fact that he is in reality a thinly veiled theif. if you want to make good relationships with people and be able to trade on forums and the like easily then you need to be 100% honest and up front about everything. I always am in my ads and dealings and I think my trader rating bares that out. a good reputation takes ages to build and seconds to destroy and to me that is worth far more than a couple of extra bux by ripping someone off.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
