Is your LCD a HD one? you should just need to tune the tv so it picks it up, maybe your not in a HD area... i dunno im not a tech...
HD ready. I tried tuning it both auto and manually with the frequency off the Channel 10 FAQ page, but it picked up nothing. Is there a way to find out if I'm in a HD area? I didn't even know there was HD and non HD areas.
  • Replies 40
we don't get the Ten HD channel down here :laugh: . Ten is always a minimum of 5 mins late. I have to set my recordings to run 10 mins over to garentee i don't miss the end of shows.
I'll sign it anyway though
SD and HD run on same frequency, if you can get one you should be able to get the other.
Maybe you only have an SD tuner in your TV? HD should be channels 1, 70, 90, 20, 30 etc...
http://www.samsung.com/au/consumer/detail/...=LA46M81BDX/XSA
Unless I'm reading something wrong, its full HD with an integrated HD tuner.
As for what channels are what numbers, none of the channels were set to anything through the regular aerial...I tuned in ABC, SBS, 7, 9 and 10 etc with the auto store function. But I could have channel 10 set at channel 4 if you know what I mean?
brilliant news, f1 is on 10 HD and much earlier this week too....9.50 vs 11.25.
everyone needs to watch it, and thanks Ed for fixing this so quickly :D
what can i say
dinner with one of the chicks from programming helped...
slightly :)
let me see if i can continue the goodness
Are you serious? You pulled this off? If so, you rock.
Dez - Glad you got it sorted! Now lets hope Ten can continue to show it live on TenHD :ermm:
what can i say
slightly :)
duncan and troy are right. channel 10 intentionally have their lame live crap like rove and big brother running over time, all the time. partly because they cram in more adds, and also it farks everything up. duncan is right. if bb runs to say 9:40 and all other channels programming starts at 9:30 no one is going to want to switch over only to have missed the first 10 mins of that show. also it nabs people who switch on at 9:30 for whatever is after BB and they get stuck with the last 10 min. I've also noticed ch10 chop off bits of shows. especially the simpsons they seem to often chop off the last 1 or 2 seconds of a segment. really pisses me off.
well i dont like f1 but why not play it on TEN HD as that beats playin the same damn f**kin thing!!! all these ad's about variety and more shows.. then they chuck in the couple of late night movies and a couple of docos.. worst shit is they play double bold and the beautiful.. such a shit show.. what has driven the housewifes to such boredom that this shit is entertaining?
also ed... please tell ur mofo wanker boss to equalize the volume between ads and tv shows.. u always gotta turn up the tele to watch the shows and then ads come on and are real f**kin loud and have more clarity than the shows.. makes me not watch 10 as much as possible.. will get the same rep as 7 did for STILL not showing the last two eps of heroes.. what losers
ps you can take him out to dinner too if that helps lol :D
oh and take FRIENDS off too.. gay and old.. throw it in the DON'T PLAY bin along with seinfeld
Edited by .:: GimpS-R34 ::.
  • 3 weeks later...
Program/Commercial Time
Received Call Type Details
------------Complaint-------------- Praise----- Enquiry--- Request/Suggest----- Comment
SPORTS
FORMULA 1 --------------------------- 1-------------------------------------------------Thank you for showing this live, it has made such a difference.
ok so whos the one that called up to praise me...
lol
Gimp - those shows are still shown, even though they are old they rate well... high ratings = money...
  • 3 weeks later...
hhaha I assumed compliments went to the same round filing cabinet that complaints go to.
scheduled start 9:40
current time: 9:49
no sign of f1.
funny how shows accidently run late but never, ever early
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
    • I get you, we’ll see I’m aiming for 200ish kw now and hopefully 300rwkw down the line after some upgrades maybe like headstuds, E85 flex fuel etc  so trying to make it final for that now, I can get a GTT airbox for $280 so it’s not too bad but not sure if there’s better ways to spend that money. I seen online they say pod filter which isn’t enclosed isn’t good especially for a plus T.      hard to say what to do
    • Meh. How much power can you make from a +T anyway? I wouldn't have though it would be enough to challenge the airbox. It's not as if it's tiny compared with the turbo one. As to putting a pod in a stock airbox .... it's not the filter element that would be restrictive. It would be the air inlet to the box that would be the narrow point, which you could open up regardless of what element was inside. On my R32 I opened up the sort of triangular opening in the bottom front corner of the box, deformed (heated, moulded) some 4" stormwater pipe to fit to that opening and punched a 4" hole down through the inner guard to the spot where the stock intercooler used to be. This was purely in the search for a cold intake, but you could do something similar if you need to open up the inlet side of it. The AFM tube size is the same for both NA and turbo, so the outlet from the airbox is same same anyway. If you're going to do the right thing, then an aftermarket ECU won't care about the AFM (ie, you can get rid of it). But even if it was still there, people pull >300rwkW through them all day, and I suspect you won't be going there.
    • R34 RB25de Neo by the way ^
