just recently my car isnt starting without the need of a jumpstart. (r33gtst) i went to bob jane and checked it out. battery is perfect, alternator is perfect.
came up as an error though as power drain or something like that.
this has got me puzzled.
what could it be?
https://www.sau.com.au/forums/topic/223779-car-keeps-needing-jumpstart/
Have you checked the battery terminals?
Loose earth cable?
Happened to me couple of days ago, resulting in new terminals.
These two things that springs to mind with situation like this.
Hope it helps
Cheers
Grant
i had this problem in my old vk... (P.O.S. btw)
turned out it was dirty battery terminals... the battery was leeking some shit out (whitish in colour) that was coating them and preventing it connecting...
wash in hot water see if fixes :thumbsup:
also check all your belts for slipping
Yep, what you want to do is like GTR-ben said, grab a multi meter and use the amps setting and do some testing.
Another good place to test is your fuse box, when the car is off, pull a fuse on a circuit and use the multi meter probes to bridge the gap and if the car is off you should get next to nothing. (Make sure the probes are in the AMPS terminals of the meter, because they are usually different to the volts terminals)
Common things that do cause current draw when the car is off are internal lights, alarms and shorts to earth.
So that should at least allow you to find which circuit is draining ur battery overnight.
Hope that helps dude.
How old is the battery? Just because it checks out as ok doesn't mean it's accepting and holding charge. Check the battery voltage before you even crank the engine. Then check it while you crank the engine.
Is the alternator working properly, and the regulator. If the regulator (built into the alternator) is cactus, then it might be overcharging the battery. And batteries don't like being overcharged.
Hmmm, that is odd, batteries dont normaly last 12 yrs, i have an odyssey that is only a few yrs old and had to replace that on the weekend, you should here it spin up now with a 1000cca dry cell.
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
