After brakes come rims.......Ok, to open up the field with rim selection, who knows of any 17" rims that will clear my coming soon set up? Clearly both in diameter and laterally? Such a thing? 17" will give me cheaper tyres, the rims may be cheaper themselves and I've heard that 17 x 9.5 is the optimum handling size for an R32 GTR......
Thoughts? Suggestions?
17x9.5 +12/22 TE37's or LMGT4's should clear. I know they will clear 355mm Stoptechs, but you're best to get a measurement first. You can try mine out if you want, once the brakes are on the car, or give me a template and I'll measure for you.
  • Replies 204
Posted Images
there is an easy answer to that. TE-37s. 17X9.5 with the right offset will clear (i think the 17X9.5 TEs come in +25 and +12 but 9.5 with +12 offset will sit just outside the guards). even the 17X9 +20 will be perfect and give you the guard clearance you need and can take a semislick anywhere from 235 to 255 comfortably. that would be my choice.
Thanks for the info and the offer. Trial fit would be fantastic. I'll give you a shout once the brakes are on the beast. I guess the ID needs to be something like 416mm and the measurement from the outer face of the disk to the inner side of the spoke needs to be about 70mm.
Wow. 17" is 432 mm. If I need 416 ID that's 8mm per 'side' left over to make the body of the rim. Can I ask how you 'know' this (other than being the revered BB of course). Own personal experience? Cheers. The 17" option looks good, thoughI bet they're just as hard to find.....
Most 17" good rims have an inside diameter of approximately 400mm. The 432mm you have listed is not the amount of brake clearance you have available.
Agreed. I was suprised that a 17" rim would yield 416 ID which is approx what I'd need for the 355s.
well I have definitely seen AP 6 pots and the like with 355mm rotors under 17inch TE's. haven't tried it myself personally so definately measure up first. I'm not sure that you'll realy need 416ID though. check the templates and measure up a rim too. from memory my enkei NT03s are over 400mm ID and the Weds TC-05s are too. the BBS LMs I have were under 400 as they step down a fair way. it may be worth getting a AP 6 piston kit with 343X32mm rotors so you can pick from a wide range of 17inch wheels as they will fit under heaps of different 17s.
the 355s should fit under the 17inch TEs though. A mate of mine (giant on the forum) was able to fit his 18inch TE37s over his 380mm R35 GTR Brembo set-up and they have pretty big calipers.
Well from the templates posted above (which I already had) the cl of wheel to outside of caliper radially is 203mm. Allow 5mm clearance and you've got 416mm. Phunky is going to use the template on his rims and let me know so we'll see how that goes.
The 17 x 9 +22 Weds TC005 will clear a Brembo F50 caliper with 355mm rotor. I just bought a set and they came off an R32 GTR running the 355mm Brembos. So you can get some 17"s but i would definitely be waiting and trial fitting rather then all this other guff.
I have had so many brake setups and wheels combos now because the suff i have read and published data doesnt alwas paint the whole picture
The AP stuff may or may not include a clearance ie calliper + 6mm.
You need the clearaace for three reasons:
1: Rims distort when you are cornering.
2: You can get small stones stuck between the calliper & the inside of the rim which will grind the fk out of them.
3: On the track you get bits of rubber picked up & melted onto the inside of the rim. Which can & do catch fire if they end up near the calliper when you park up.
Anyway if you can find someone ith a 17" Volk (Mine haven't arrived yet so I cant help,sorry) it is easy to check.
The 17 x 9 +22 Weds TC005. I just bought a set
copy cat. :O pics big boy. now all you need is a GTR to go with them. :P there are plenty of dirt cheap ones at the moment.
also, I want some AP's with this slot design...lol.
The +22 offset is going to kill me. I am not sure they are going to fit inside the pumped up guards. :laugh: They look so cool on a friends white S13, so they are the only pics i have at present. Have to find someone silly, ahem, kind enough to trial fit them on my car so that the panel beater can give me the gods honest truth of whether they will fit :sick:
The +22 offset is going to kill me. I am not sure they are going to fit inside the pumped up guards. :ermm: They look so cool on a friends white S13, so they are the only pics i have at present. Have to find someone silly, ahem, kind enough to trial fit them on my car so that the panel beater can give me the gods honest truth of whether they will fit :wave:
What do you need Troy, some 17x9 +22's to trial for the panel beater? Sorry, bit confused as I thought you said you'd bought some already. BUT, if you do need to trial some then you can trial mine mate.
I think they should be ok. When I insert the spigot part of the drawing into the gap in the wheel up to around half way there is clearance, but if I push it in all the way the 'caliper' touches on the rim slightly.
I'd check it out in person to be 100% sure
TX5 Scott has my car and Jarrod/Ryan have my collection of wheels:) Just need to sweet talk them into fitting the wheels and then getting it down to the panel beaters :) Then the shitty part starts, paying for more panel work :(
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
    • Not yet quite as bad as what we've seen a Jim Berry clutch do in an R32 GTR though when it decided to cut a chassis rail in half... Still very very gnarly and a great reason to avoid.
