From what he was saying at the last ben simpson cruise, he swapped to smaller turbos and made around 230kw.
My car made 230kw with standard turbo's and 11psi, he has 2860-7's at 18psi and 230kw. Something is not right with that car.
Spot on! According to what he told me, his tuner thinks that's an expected figure. I say he's an idiot
word... even N1's which are just stockers with steel wheels can get over 300 with ease...
stockers themselves would go past 220 safely if they werent ceramic...
-D
Took this one today, quite like it :)
/ol school merc
much love for the merc. needs chopped roof, fresh white walls and the chassis rails on the ground then it will make womens clothes fall off (well my clothes at least :P)
um tbh steve i dont really know, last i heard he was sitting up and they put him in a wheel chair to move around instead of being in the bed all the time.
but his dad called my mum and abused her over the phone, and alot of other stuff has been said to me from his sister and brothers gf, saying how i ruined his life and i need ot be careful that karma will come and get me stuff like that
even tho he could feel his legs could wiggle his toes and was on panadol for pain relief
go figure.
yeah i know that and he had alot of back trouble for a long time, and cause he had a pre existing back injury, the accident flared it up....but his family and what not still felt like they had the right to ring up mum and abuse her over the phone
my mum did the right thing and spoke to charlie to see how he was going etc and not once did his parents ever get in contact with me to see how i was going.
it doesnt bother me tbh but still just seems a little unfair on the way the have dealt with it
but oh well what has happened has happened, ive had to deal with it but whe u get pm's on facebook saying things like why did u delete me off of facebook (from someone who i dont even know) and that you have ruined charlie life he has no job no car and cant walk............it really brings you down
just because i wasnt as physically hurt as what he was dosent mean im not scarred on the inside
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
