I'm sure I'm just one of the ignorant fools out, but isn't mineral oil vastly inferior to synthetic? Of course a TERRIBLE quality synth is going to be worse than a really high quality mineral....but since they're the same company....why would you use M5000??
The only stupid question is one that isn't asked!
Minerals these days, from reputable companies, are fairly well refined oils...there is nothing wrong with them as such and it's more about what the company does with it than whether it is mineral or synthetic. About the only advantage synthetics have over mineral, no matter how well it is produced, is the ability to achieve certain ranges of viscosity (10w40 for example). Also, there are some additives that can only be put into a semi or full synthetic recipe. Also note that despite the name M5000, it is actually a semi synthetic (30% polyol ester, 70% mineral thereabouts) in order to achieve 10w40 viscosity and take the additives that make Sougi so special :D
And the reason you would use M5000 is because S6000 is completely out and some Sougi is better than no Sougi lol...unless you've got a hard on for nothing but full synthetic. But it too will deplete soon and then you'll have to go the way of another company or give Syn-X a go (this oil isn't going anywhere anytime soon, it's their number one seller).
Also the pao and ester (group's 4 and 5) don't break down as quickly as a mineral oil due to the impurities in the mineral oil. Keep in mind that mineral oils are really heavily processed before being put on the shelf, and that mineral oils certainly have their uses for worn old engines etc...
hmm...good food for thought there Birds, appreciated :)
Unfortunately, not because I'm a fanboi or anything, but moreso because I'm not entirely keen to take a (no doubt non-existent) risk, I'd rather still to a full synth just "in case" lol....although I might still give it a shot. What's the price on the M5000 Birds? That'll probably sell it to me.
Regarding the breaking down of the oil, I change every 5000kms (oil and filter) anyway, so that should cover my ass lol
i think m5000 is around $35 and s6000 should be about $60-70
Amsoil makes good quality synthetic fluids, they are formulated and manufactured in the US, many people use Amsoil engine oil with their E85 fuel tunes as it works well with it where some synthetics e.g. Motul 300V don't
hope that helps
danny
Shit, forgot to say this lol...it's probably the most important difference between mineral and synthetic too, but then, I thought most would know this anyway.
M5000, I think I sell it for about $40-45. Troy, if you're changing every 5,000km you should have no trouble using a mineral or semi...but I understand completely, it is difficult to get past the barriers of habit and what you're used to. That's why oil brands end up with fans for life...for some, engine oil is a bigger decision than buying a house lol. I change S6000 every 5,000km...unnecessary but I'm emotional about it :P
haha always got your back bro
*pulls gangsta pose*
That's why sougi will be so badly missed, the fans feel betrayed and also poorer
I bought elf 10w40 oil thinking it was full syn but its only semi. Only 5w40 grade is full oh well next change. Has anyone had any experiences with elf oils?
Some people i knew started using it around 2 years ago when a bunch of places in Sydney started stocking it. Subjective feedback was negative and those people no longer use it.
Wow thanks for the fast reply. Guess i'll just use it now and if it's bad i'll just use 300v
ELF make very good oils. I have been using there products for ages and there fully synthetic range is only $50 for 5L. They make a fully synthetic 10W-50
I found it make my engine more quite and when i changed it every 5,000 is wasn't ever black.
skisII care to explain why feedback was negative and some proof to back it up as to why its poor? Cant be too poor if the Red Bull and Renault F1 team use it.
Edited by SIR_R32
im sure the oil is fine but oil going black is a good thing it means the detergents are picking up the carbon deposits correctly.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
