I just bought an R33 GTR V Spec that just got imported from Japan and i'm wanting to do an oil change but was unsure what synthetic oil to use.
Have been looking at using Nulon hi tech fast flowing synthetic 10w 40 on the advise of a mate but just wanted confirmation.
Nulon 10w40 is a decent oil but way over-priced for a semi-synthetic. Spend the extra 10-15 and go with motul 8100 xcess, or whatever the new one is, or royal purple fully synth for the same price (if you can find it).
Edited by Galois
Nulon 10w40 "high tech whatever" shit states on the back that it's 100% synth, not "fully synth"
that being said, the waxes and shit in there are classed as synthetic, so it may be one of the 100% but actually 75% synthetics. Either way, I'm running it and there's been no issues, I'm yet to see how it comes out though.
Haven't personally but all my workshop customers love it, they use it in every car they can. Should go well in your car, do let us know :)
thats good to hear, $32 and in stock at autobarn :)
will be going in tmrw
Nice to hear, give us a report in 5000km :)
It should run much thesame as Sougi, it's all the same viscosities and some of the additives...plus some that Sougi didn't have.
Sougi is very deceptive, it looks like regular $5 XMP (XTR whatever) shite. I've been running Sougi S6000 full synth in my GTR for acouple weeks and for all intents and purposes it feels like just like my old oil (Motul X-Cess 5w-40) but interested to see the condition of the oil is (compared to the Motul changes) when it comes to changing the oil.
gw oil lol we sell that at Woolworths. I thought its some cheap shit stuff.
Going Motul 300v for my next oil change. Been on Royal Purple for too long, want something new!
lol yes and quite rightly...I'll never forgive GW for doing that to the brand. That Woolworths spec oil is good at what it does, i.e keep old pieces of shite running into the ground, obviously a different drop of oil to the more expensive GW oils :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
