Google "Fumoto" oil drain valve if you haven't heard of it...
Installed one of these on my R33 a while ago and not only does it make oil changes as easy as flicking a switch (no more sump plugs and washers and oil pouring out over your hands/spanner), it looks kind of cool too :)
Very cheap for what it is!
The k&n with the nut, what a brilliant idea! Why don't they all do that...
well considering filter is only meant to be hand tight I would think its pretty pointless just like changing your sump plug washer..dont overtighten things in the first place and you wont have any problems :thumbsup:
Thanks for the advice Rolls, I think I'll go the cheaper option Motul, does seem to make sense when you put it in the new motor perspective.
Now... Where do I get my hands on it? Supercheap doesn't stock Motul right? I'm in Sydney.
Where do I get a Nissan oil filter?
if your after motul 4100 turbolight check out just jap in the traders section... bought 5L for 80 odd bucks including postage which only took a day
I use one of these,just like you said makes oil changes a breeze. :yes:
It definitely looks good. How secure is it though birds, I'm guessing you've never had any trouble? Does it feel like the safety latch will protect against a wayward stone flying up under the car?
I've only ever done filters up hand tight and only ever managed to undo one or two by hand (of a couple of dozen changes at least). Having that leverage/grip makes it so much easier. Though you can always just stick a screw driver through it (never done it myself but have been tempted).
Isn't 4100 turbolight usually a fair bit cheaper than that? Seeing as 8100 is usually $75-80?
yeah it was like 60 bucks for 5L postage was $20 ish.... lol the screwdriver trick... i thoroughly dont recommend it - some say its ok - for me an oil change usually takes an hour.. it took days to finally wrench my old filter off after breaking just about every tool i had
Doesn't sound right, 8100 xcess is only $60 when you shop around, 4100 is cheaper again. Worst case 8100 is $80, 4100 should never be that price.
well I would think that means your doing them up to tight wouldnt u?
Also are you putting them on dry or wet, smear a little oil around the seal and half fill it with oil before you put it on..
Anyway, I guess some people just dont get it, which is why they make filters with little nuts..
i dont see why anyone would use a semi synth 4100 when you can get a full synth 8100 for about the same price .. is it because its called turbolight people think its better for turbos :unsure:
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
