Google "Fumoto" oil drain valve if you haven't heard of it...
Installed one of these on my R33 a while ago and not only does it make oil changes as easy as flicking a switch (no more sump plugs and washers and oil pouring out over your hands/spanner), it looks kind of cool too :)
Very cheap for what it is!
The k&n with the nut, what a brilliant idea! Why don't they all do that...
well considering filter is only meant to be hand tight I would think its pretty pointless just like changing your sump plug washer..dont overtighten things in the first place and you wont have any problems :thumbsup:
Thanks for the advice Rolls, I think I'll go the cheaper option Motul, does seem to make sense when you put it in the new motor perspective.
Now... Where do I get my hands on it? Supercheap doesn't stock Motul right? I'm in Sydney.
Where do I get a Nissan oil filter?
if your after motul 4100 turbolight check out just jap in the traders section... bought 5L for 80 odd bucks including postage which only took a day
I use one of these,just like you said makes oil changes a breeze. :yes:
It definitely looks good. How secure is it though birds, I'm guessing you've never had any trouble? Does it feel like the safety latch will protect against a wayward stone flying up under the car?
I've only ever done filters up hand tight and only ever managed to undo one or two by hand (of a couple of dozen changes at least). Having that leverage/grip makes it so much easier. Though you can always just stick a screw driver through it (never done it myself but have been tempted).
Isn't 4100 turbolight usually a fair bit cheaper than that? Seeing as 8100 is usually $75-80?
yeah it was like 60 bucks for 5L postage was $20 ish.... lol the screwdriver trick... i thoroughly dont recommend it - some say its ok - for me an oil change usually takes an hour.. it took days to finally wrench my old filter off after breaking just about every tool i had
Doesn't sound right, 8100 xcess is only $60 when you shop around, 4100 is cheaper again. Worst case 8100 is $80, 4100 should never be that price.
well I would think that means your doing them up to tight wouldnt u?
Also are you putting them on dry or wet, smear a little oil around the seal and half fill it with oil before you put it on..
Anyway, I guess some people just dont get it, which is why they make filters with little nuts..
i dont see why anyone would use a semi synth 4100 when you can get a full synth 8100 for about the same price .. is it because its called turbolight people think its better for turbos :unsure:
    • Was there ever a model of the Stagea m35 that didnt have a badge on the grill? I thought I saw that somewhere, some aero edition or something? I cant find it again? davemoto
    • Its a 2002 vr-x four VQ25DET, silver. Coil overs, lowered, polished alloys and sport exhaust. Bit of a project, was sitting in a shed for a while but runs and drives great.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
