Unless your engine has been rebuilt recently, the filth isn't necessarily a bad thing...it is now one with the engine and probably keeping things nice and quiet :thumbsup:
All RBs are dirty engines, they produce a hell of a lot of carbon, which is why the better oils come out pitch black after only a few thousand...so I wouldn't stress over it. Unless you have engine issues, the only cleaning you need to do on the inside is to use a decent petrol oil. The GW petrol oil products are fairly detergent heavy, so maybe whack some Syn X 3000 in there and it'll do all the cleaning you need.
For the record, any diesel oil with an SH/SL/SM rating appearing after the will work in a petrol engine.
Cheers, will give it a go :)
Syn X 6000 will last you to 10,000km if you really want it to. If it's a daily driver and you don't thrash your car everytime you go out, then you can draw a full synthetic out to 10. I am like you though, in that I like my 5,000km intervals. By then the old RB has made any decent oil very black!
I cant handle the thought of not changing my oil for 10k :)
But since it takes me a few months to put 5k on the clock, time vs kms comes into it anyway. So 5k works well for me.
And easily done at rrp ~$55 for syn-x 6000.
also, cheers to you for bringing the GW to my attention in this thread, otherwise I may never have tried it.
Finally got in on the EDGE bandwagon..runs nice as always..now Moodles is making me nervous..
You would get even more nervous if you read the oil control in RBs for circuit, drag or drift thread (in it's entirety): http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/
Picked up some of the Syn X 3000 for the daily, worth a go for $19, but not brave enough to put it in the Skyline... :)
Go get a 20lt drum of Syn X 6000 for the GTR; it's $150!
I've been using the Syn x 3000 for the last few changes in the daily (I run it to 10 000kms), and am up to nearly 4000km on my first Syn X 6000 fill in my Stagea.
Syn X 6000 replaced Sougi S6000 in the Stagea when I fitted my new turbo; I can't tell the two apart.
Even the slight difference in viscosity hasn't revealed anything unusual, although the VQ uses a 7.5w30 from the factory, so at 5w40; it's probably more suitable than a 10w40 grade.
No tensioner rattle at cold start up, same as Sougi, whereas Motul Turbolight would start getting a tiny rattle around the 4000km mark; obviously starting to break down a little.
It's very smooth, revs freely, and the level hasn't dropped at all; and VQ's are known for using a little oil.
I'm not an oil expert like some on here; but based on it's performance so far, I know I'll be buying another 20lt of Syn X 6000.
where from? i've asked a few repcos and they dont seem to stock it? 150 for 20L, and scott mentioned getting his oil for 120 for 20L? where?
Go to the GW website and and use their contact page, Mr A Vicary responded within one business day, as to where I could obtain their product, very good customer service.
One of the owners, good guy :)
Can't believe how many people are using GW now. Not bad for an all Aussie product!
It is a very good oil, I ran it for 5,000km during my last interval. For those who don't want to fork out for 6000, there is 3000, which will do just as good a job.
Yes, thicker oils create a thicker/stronger film between moving parts...the oil has to get in and out of there in the first place, though. Thinner oils are generally better at circulating an engine with tight tolerances and servicing an overhead valve train. The key is striking a balance between the two!
Most engine wear happens during cold start up and cool down - 10w60 and 10w30 are the same thickness on start up, so out the window with a lot of theories about viscosity choice being responsible for engine failure. I've said it many times before: you can't really go wrong with viscosity choice...there are only suitable and more suitable grades. More important are regular oil changes and that it comes out filthy black!
not sure what you mean by cold starts being responsible for engine failures
In the case of a high powered turbo engine, are you sure the most wear wouldnt be when its on full load/boost in a highish gear (eg. 20psi at 7000rpm compared to 2500rpm off boost) ?
Id say for example , a dyno run would give more wear and tear than 5-10mins of cold start.. and at this time the 10-30 oil could be breaking down and becoming a 10-20 oil which could be a problem with bearings wouldnt it? so not sure i agree that viscosity isnt important ,
Ive always been a bit confused how oil can be thinner when its cold, cause when your pouring it appears thicker than when its comming out the sump hot.. can anyone explain that?
It's not thinner, it's relative. For example a 10w-50 oil will have the same viscosity as a straight 10 weight oil when cold but when hot the straight 10 will be thinner. The 10w-50 will have the same viscosity as a straight 50 weight oil when hot. All oils are thicker when cold and all of them are thicker than ideal for an engine when cold.
A bullet through the engine block will also cause catastrophic failure! I'm talking about normal driving here, and general wear to components eventually leading to a failure.
The reason Taxis get such high mileage to an engine, despite being thrashed in stop/start traffic all day long, is because the engine doesn't stop to cool down. They have a very low cold start to kilometre ratio.
Oil is thicker when it is cold. The first number on a multi-grade oil, e.g. 15w, refers to viscosity when cold. The second number, e.g. 40, refers to viscosity when hot. These numbers are not comparable, as hot and cold viscosities are measured on different scales at different temperatures - this is where people get confused, thinking the two are related and that multi-grade oil gets thicker as it gets hotter.
If two oils have the same first number and different second numbers, they will be of the same thickness when cold...but different when hot, due to different additives.
  • 1 month later...
Yes the first number is a cold pouring index not a viscosity number . Also the hot or running temp viscosity changes when the oil gets really hot with hard use , this is why oils like say a 10W60 stand up to high temps better than a 10W30 would . If you never get your engine oil really hot ie track work hot the 60 weight just adds a bit more drag at normal running temps . Its really no extra protection and costs a small amout of power and some extra fuel .
Most serious oil people will tell you that viscosity choice should be based on the oil temps your engine runs because this has a large bearing (no pun intended) on the oil pressure you'll have .
Sadly in recent years manufacturers are going with lower oil viscosities partly because clearances are smaller but generally because less oil sheer drag means better fuel consumption and possibly cold start emissions dramas . Throw in "extended oil drain periods" as the yanks call it and it adds up to limited engine life IMO in a throw away world . Most of your average snot boxes are considered used up at 100, 000 Km and thin green oil doesn't help them in te long run .
BTW do some research into ZDDP or Zinc Di Alkyl Dithio Phosphate because this is the good stuff used in older spec oils that protects high point load bearing areas like turbos and valve train components . RBs have direct cam lobe on bucket valve trains where "Green" engines are growing things like roller rockers and or roller tips so these engines don't die with these late eco cat friendly oils .
Some of the best oil info comes from pushrod V8 sites because these engines with big cams and very high poundage valve springs to control big heavy valves need really good oils to stand up to the high point loadings - and green oils kill them .
Have another look at the Mobil 1 synthetic sport bike oils because these are higher in ZDDP etc because sport bikes are more like F1 engines compared to car engines even good ones . High revs uneven heat loadings hard worked valve trains .
GL Lubricants sell Mobil 1 Racing 4T in 10W 40 which is about righ for a street RB , its road oil BTW not competition regardless of what the name suggests . Porsche used to specify it for some of their turbocharget road cars and HRT were using it (10W50 version) in the pre E85 era , not sure what they use nowdays .
A .
Edited by discopotato03
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
