Generally, unless you're radically changing oil viscosity or the old oil is very old/dirty, you're usually fine to just get the oil up to temp, drop it (don't burn yourself) and throw a new filter on with some fresh oil of your choosing.
Thanks for that, thinking of going penrite HPR 5w-40 full synth. Or the everyday+ 5w-40 semi-synth. Edited by Zrobe
Could all be placebo but...
Going from Motul 8100 xcess 5w/40 to Gulf Western Synx 5w/40.
The motor feels a little more..."lethargic" during initial start, like it won't rev up as freely/easily/quickly.
Could just be the weather....
I checked out the spec sheets of both Motul 8100 xcess and Gulf Westerns Synx6000, both were very similar on paper. even the Penrite HPR 5 is similar....
Could be just the cold weather...or there is something different between them that isn't counted on paper.
  • 4 weeks later...
hmmm.
missus mazda 3.
was using penrite everyday syn 5w40.
engine has approx 130k.
went to motul 8100xcess.
feels alot quicker and more responsive.
might be the oil.
I use the cheap $22 GW Synx-3000 semi-syn oil in my car & doesn't notice anything compared to what ever stuff was put in there by the work shop before.
I changed it every 5k km or 6 month & the car (used) to be a daily driver (no tracks) so I don't see the point of spending >$40 for oil.
I've come to the same conclusion too, when you work out what you save over a 100k km on the $70 oil it adds up to nearly the cost of a low K wrecker motor.
Have read the last few pages of the thread but to be honest it's a bit all over the place. Just wanting to know what brand/weight of oil to use in my car.
RB25DET Neo with 130xxx k's on it. Will be my daily but I will hopefully be doing a few track days and 6-7 drift days per year and I will be driving it fairly hard. Where I currently am the temperature he's down to about 0 overnight and about 20 during the day.
Not really sure what brands are good and what weights for climate/engine age so any info would be handy, thanks!
What brands would you suggest? Or doesn't really matter as long as its fully synthetic?
This engine won't have been started in about a year either, am I best off buying some helper stuff to put in at first start up then changing the oil once I know it's running fine?
Been digging through this thread quite extensively but still having trouble making up my mind, hence my current post.
Just wanted some opinions on what oil i should be using for my next service. This will actually be my first service since owning the car so i don't wanna skip out on anything. I'm willing to spend big $$$ to make sure my pride and joy is running at its best. Through my reading, i've come across some good rep for SYN-X 3000, Mobil 1, Motul and Royal Purple.
CAR DETAILS
'98 Skyline R34 25GT (Coupe)
Automatic
Approx. 93,000km
Never tracked
It's been recommended to me, based on the number of kms the car has done, that i should be going for something along the lines of... Fully synthetic 10W-40.
Any info would be appreciated,
Cheers
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
