why is it mechanics always recommend 15-40/50 when car manufacturers recommend 5-30/40
General mechanics usually carry 15w40 and 20w50 mineral oils to keep running costs down. These two oils will help service 95% of the cars they come across. The game is changing though, with many modern cars that call for 10w30 now entering their "non-genuine servicing" ages...requiring general mechanics to carry specialist oils too.
Most workshops that I supply oil to, I have convinced them to keep only Syn-X 10w40 and Hi-tech 20w50 in stock, as Syn-X is only slightly more expensive than mineral 15w40 by the 205 drum, and can be used where both 15w40 or 10w30 are needed.
I got motul turbolight 10w-40 for the n/a skyline :) 60 bucks a bottle opposed to 80 for 5w-50 mobil1 .. its run 93,000 ish
I use shell helix 15w-50 for my sexcel .. which has run about 265,000 ... only about 30 bucks a bottle :)
turbo light isn't a full synthetic, should be able to get a full synthetic motul for $60-70 depending on where you buy
Fml. I went to turbolight cos i prefer to change my oil more often with a good enough semi synthetic oil like the turbolight than a full synthetic like the mobil1 5w50 changed not as frequently ...
I got it from Repco?
My 34 also uses an awkward amount of oil .. 3.2-3.5L is enough for a topup usually so i could effectively get about 3 topups if i was to buy a second bottle. if it used more i wouldnt feel so bad changing oils more often but its such a waste to throw away the remaining 1.5-1.8L :(
I thought most skylines used about the 5L mark though ... no idea why my tank is so small
Then what - just use it. Pretty sure 8100 only comes in 5W-40, I have it in my car now for just over 2,000kms and no problems. Car runs smoothly, oil has turned dark brownish, can't notice any issues. I'd recommend 8100, either one.
8100 comes in multiple variations ov 0w20, 0w30, 5w30, 5w40 and 10w40
does anyone know if you can buy Motul300v or the Royal Purple at autobarn, repco etc?? prices??
chaddy autobarn has both... royal purple comes in at $100 or $200 depending and motul products range from around $55/5lt to $59/2lt
shitloads of new cars now require 5w30 birdman.
wut...
LOL i just mean that since my car only uses 3.2-3.5L of oil 1.5-1.8L is remaining and if i was to change to a different oil itd be a waste of the remaining few litres
Um... I'm pretty sure it takes more than that, is your sump bashed in?
nah its in good shape ... im not too sure why it takes so little I thought it would take around abouts 5 as well?
I saw someone else with a n/a r34 and it only uses about 3.5 as well but we seem to be the exception ..
Yer. The general mechanics don't see too many of them because people ususally go genuine servicing on new vehicles. Every now and then I'll sell a 20 litre container of 5w30 to a mechanic servicing Euro cars, but it's rare.
Are you changing/draining the oil filter too? Draining oil when hot and waiting a good hour or two?
Really? Falcons have been running on 5W30 since the AU? Not sure about the Commodes either but I would expect something similar.
yeap changing and draining the oil filter as well, and the oil was quite hot when we drained it .. never waited an hour + though didnt know i needed to confused.gif
You don't *have* to wait an hour, but there's quite a bit that slow drips out of the engine if you leave it there that long. No harm in getting out as much old oil as you can.
It is true the AU Falcon manual recommended that, but how many of them would still be running on 5w30? They were about the only car at the time, besides the Mazda Tribute off the top of my head, that asked for a 5w30. There was not much call for this oil in Australia until the last couple of years, hence many mechanics did not reglarly stock it and there weren't many oil manufacturers putting it out or pushing it as a major seller. Back around the time of the AU, the Commodores were still using the Buick engine, so I imagine the call for oil was still either a 15w40 or 20w50.
I changed my oil today, after much googling and reading about different oils i decided on Royal Purple, and so far im quite happy with it,
what ive noticed so far is watching my boost guage, the turbo seems to boost earlier and the whistle sounds crisper,, my old oil was MOBIL 1 Gold,
ive ditched mobil 1, and am convinced from what ive read that Mobil 1 is no longer the best oil, it has a reformulated lower Zddp than it previous formula of years gone by.
From my understanding the level of Zddp is very important in protecting against metal metal contact thus my choice of oil, API SM oils should be avoided
Royal Purple, Redline and motul 300v have high levels so they are my choice oils now... all of which are well priced
Your understanding sucks :)
From my understanding OIL is very important in protecting against metal/metal contact. Nothing wrong with SM. Many other parts in your engine will fail before it succumbs to the "adverse effects" of an SM oil.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
