  • Replies 54
To be honest that was kinda expected. Course was made for smaller more nimble cars. I believe an S2000 holds the record for the touge ??
I wana see that same race on tsakuba and then we will see who gets there A#@ handed to them :geek:
Yeah...i kinda agree with you.
Still, it was a good comparo when you think about it.
I suppose on one hand it shows the old FD has plenty of life in it yet - it is in my mind one of the finest most balanced chassis in the world and taking into account it was created more than 12 years ago, makes it something pretty special.
What is it with Mazda and massive chassis' anyway?
Horses for courses as they say and without doubt and of no real surprise, the GTR isnt the horse for that course...
overall i thought the gtr looked poised and balanced, benefits of awd i guess. while the rx7 had a very loose arse.
was a good watch
Thats just 480hp 4wd versus 450 Rwd... it couldnt be helped.
Plus the fact that the Rx7 was 500kaygees lighter...
I think the Roox was balanced and poised by the way but i have to say Tsuchiya manhandled the Rotor...
Im almost sertain Tsuchiya wouldve been closer if the drivers were swapped and yep, the result would have been different.
Edited by m3gtr
balanced?? the fd rx7 has always been praised for having the most balanced handling
Im not suprised it owned the GTR... its always had better handling than the previous GTR's and as for a bigger track like tsukuba... what makes u think the GTR would win???
its still heavier, and slower.. sure it might be faster off the mark.. but once theyre movin, theres no stopping a tuned RX7.. i know, ive had one and even thou it had about 60kw less than my GTR, it was MUCH quicker
BumbleB, i said I thought the FD was and still is one of the finest driving chassis' in the world already, didn't i?
I still stand though, on the fact that, if the drivers were reversed, the outcome would have been different.
Interesting, even though the RX7 is light and powerful with plenty of corner speed, i would have expected the GTR to be quicker with all its gissmos. It went damn close and i think you can tell by the steering inputs that if they did the run 10 times the GTR would be consistantly quicker, even if the outright quickest lap going to the RX7.
So, seems despite all the reviews, Nissan still have not been able to engineer out the cars weight, the fact it doesnt feel big and heavy is the next best thing
RX7 is old school mate. Doesn't matter how balance the RX7 is, it still uses a normal manual gearbox and is RWD. Wait till you see a "fully" tuned R35 - then we'll see if there's anything that can stop it!
Noticed in the video that when Tsuchiya was starting behind the GTR, he kept very close right at the beginning, whereas when the GTR started behind the RX7, the driver of the GTR was nowhere as near to the back end of that RX7 as Tsuchiya was to the GTR. If drivers were swapped, im sure it would've been a different outcome. And to think that it takes a very well tuned RX7 to marginally beat a basically stock GTR says a lot about the GTR.
What makes me think the gtr will win ??? a 1 min dead lap time at tsukuba !!!! Not saying a RX7 couldn't break a minute i know a few have, but just not that RX7.
The touge deffinatly favours RWD cars as the fastest around it are RWD... Where at Tsukuba the top 10 cars are all pretty much 4wd, GTR's and EVO's rule tsukuba. :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
