Ok chaps, it's like this.....
I have an R32 GTR, I have run 10.6@138mph in full street trim (full exh, street tyres, soundsystem pump fuel etc)... and I wan't to go faster BUT retain the same, if not better response for the street and track. I'm looking for low 10's in full street trim. I don't wan't to sacrifice weight or suspension, or upping the gas..... more power is my only option.
Previous set up: stock rb26 (still quite healthy) 396rwkw, T517Z 10cm's, 260 poncams, PFC, fuel syst, 50hp shot of N2O- at the track only NOT on the dyno, R3C and ppgdogbox, plus all the usual supporting mods... I ran on BFG street drag radials.
I have in stock, Tomei 2.8lt stroker kit, N1 block, ported head, 272 HKS cams etc....
What would YOU use for a turbo kit, maximising response on 98ron fuel, with a total power output around 450-460rwkw... I love my T517Z's but they were running 22psi flat out at 396rwkw.
Cheers
Justin
https://www.sau.com.au/forums/topic/225836-rb28dett-turbo-choice/
  • Replies 56
People with 440awkw, stock shift gearboxes etc ... and have have run 10.40 or better, so cut out a few 10ths of a sec due to the dog box, and you *should* be running low 10's already without changing a thing.
So IMO you already have what you need, you just need to drive it to the time the car can run rather than chase power.
You wont get better response by upgrading turbos larger, even if you are going a stroker. Any gain from the kit will be well offset by the turbos.
If anything, just get a T04z, will do over 400rwkw on PULP.
If you can't run a 10.1 with a trap speed of 138mph then more power is not going to help you. You need to improve the vehicles dynamics and maybe driving style. The car has got it in it already, you just gotta bring it out.
What was the 60footer time?
im suprised you didnt point it out.. but twoogle's runs were 10.3 at 134mph with his 2530's and its been 9.7's i believe at 139mph.. so this blokes definately got a low/flat 10 in his car already seeing as he's doin 138mph.. i wonder if he knows about the 140+mph thing with andra which is why paul holds twoogle in third in twoogle across the line for the 139mph
im suprised you didnt point it out.. but twoogle's runs were 10.3 at 134mph with his 2530's and its been 9.7's i believe at 139mph.. so this blokes definately got a low/flat 10 in his car already seeing as he's doin 138mph.. i wonder if he knows about the 140+mph thing with andra which is why paul holds twoogle in third in across the line for the 139mph
this man speaks the truth...sort of...lol
correcting a couple of things said in thread...
Ash i assume the 440kw stock shift etc is me...i never raced with 440kw thats just a dyno comp figure (34psi, when racing we only ran 28psi) the car was raced with around 400-410kw.
rb26s13 you are slightly off the mark with the time stated...9.9's @ 139MPH but thanks anyway. Our car was capable of running quicker but couldnt race it to its full potential due to the ANDRA 140 MPH rule.
I think if you go GT-RS's and are willing to rev it (9500rpm) you could run a 9 with that MPH or at least a very low 10. You would have to get the cars weight including driver to around 1475kg to do the 9 though. Although you do have the dogbox so you might get away with being over 1500kg. Our car was almost as responsive as Racepace's 2.9ltr and was all over it in the midrange and ours was only running a STD nissan crank. So RS's are the proven route i think. Our car also easily made 455KW at the wheels at Newcastle Autosalon on 20psi with BP98 and over 500KW at final battle on Sunoco race fuel.
Edited by DiRTgarage
come on.. it had a 7 in it somewhere 9.97 maybe? meh i cbf thinking to hungover i just remember one of your runs was 139mph and was a 9 but had a 7 after the 9. somewhere
9.97...spot on...PB is 9.95 @ 139.6 MPH....0.4MPH from being logged for no parachute. The day the ignition DVD was filmed (WSID bracket meeting) ran back to back 9.96-9.97 then when they turned up with the camera's and insisted on massive burnouts the times went 10.0's. The last run of the day the ANDRA stewards allowed me to have one pass that they would turn a blind eye to (in regard to MPH) as it was bleeding obvious that i was holding 3rd too long. So with PB's to the 330 and the 660 in both ET and MPH on the run I looked set for a 9.8* at 140+ MPH i went to shift it into 3rd and the bastard would not go in and rolled over the line with my foot on the clutch....it ended up a 10.1 at 129 MPH.
Thats why you can see me rip my gloves off and throw them in the in-car footage on the DVD
Back on topic...a HKS T51R KAI BB has very similar charateristics to twin HKS GT-RS's in regard to airflow, power output and efficiency. On a 2.8ltr that would be my 2nd choice.
He wants response!
T04Z. On song by 4000rpm for the win.
we have a to4z on our circiut car...its laggier than the drag car and doesnt make the power, might be ok on a 2.8 ltr though.
Cheers for all the input guys.
I might look into GT-RS's then. I don't really fancy a big top mount. Even though they look sweeeet!
Mr DGarage, I remember reading somwhere that you run "modified" GT-RS's. Was that for response or for more top end??? who did them?
Do you have a dyno sheet posted up anywhere I can have a quiz at?
Cheers
Justin
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
