I Lost Omurru Out Drinking Last Night And This Is Where I Found Him....
haha...reminds me when i was in osaka and a mate went MIA only to find him spread eagle on the concrete infront of the appartment door we were staying at. we could have drawn a chalk mark around him to get a perfect homocide outline.
whats even more funny was it was our first time in japan and we had only been there 2 days so we have no idea how he managed to get back let alone pick the right floor and appartment door.
Any stains on the paint work? :)
just got back from the carwash actulaly -nah all good - took some scrubbing. :)
he scratched my wing getting up there tho :P
ahh drinking misadventures sure are fun! hahahahahah
i posted this on supraforums too...
I don't reckon i could pass out like that on his gtr.... :P
its my car - its the funniest thing i've seen all year.... and i highly approve of it.
and i take pics @ clubs, so i see quite a bit :(
this photo has caused so much controvosy. its hillarious
pukes all cleaned up[
he'd already thrown up b4 it went on my car
we weren't mucking around that night wiht drinks either... twas bad!
i'm just waiting for kyle to post in here rofl
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
    • The rod I was moving left and right you can see looking from the passenger side floor up into the center console.  IMG_8095.mov
