Hey guys, jst got my cars power fc tuned on the dyno today, it spat out 235kw at all wheels on 14psi.
Jst thought id post my printoff for discussion/criticism.
mods: Cat back exhaust, race cat pipe, HKS EBC running 1 bar and an Apexi panel filter in stock box.
The car definitely picked up mid range power but i havent given it a bit of a go yet as i would like some peoples imput on the power fc's ability to read knocks, mine got up to '28' and i dont know what that means or how much is it suppost to be.
This was in 3rd gear and backed off throttle at 4500.
any expert advice would be appreciated
-Johnny
https://www.sau.com.au/forums/topic/226506-dyno-results/
-Johnny
Nice one buddy.....can i ask how much you picked up your power fc for?
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3988291
Got mine from JDM-TUNE on ebay, i ordered it from them for 980 with hand controller and had it couriered the very next day so i didnt have to wait.
Duncan your car is amazing, what rims are you running there? jst add a carbon bonnet and the car will b perfect.
EDIT:
Forgot to add, JDM-TUNE sent my package to the wrong address (1414 instead of what it really was). Thank god the courier that delivers my area knows who i am and came to my place instead.
I emailed the seller named Willy whose PO BOX is in kew to notify him of the situation being very polite as i had recieved the product but i got no response, not even an apology.
i will now give him bad feedback and not buy from him again.
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3988665
I recently bought a R34 GTR powerfc from japanese yahoo auctions (by mistake as my car is a GTT) using importmonster.com.au The total cost was $270 so it might be worthwhile checking there.
Oh yeah I dont have it anymore .. decided to have someone else take it as it's no good for my car.
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3988951
EDIT:
thanks mate, it has 18x9.5 rays te 37's.. photo's dont do it justice! will try and get some better ones. your looks mint too. love the black.. any other plans for it?
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989285
That s ridiculously cheap!!! nice work. pity you didnt have a gtr use it with!
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989295
Im sure mate, is that a z-tune kit i see?
im ordering the bonnet and rear pods for mine before hopefully entering it into autosalon, is there an SAU section i can pop mine in?
im done for mods after i pop in the dumps and front pipes + cam gears
again, fantastic car!
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989653
Thanks mate. Just the Nismo, bottom lip and Side skirts. keep me posted and send some photo's when your done... i think can post your 34 on the cosmetic styling pages. there is a thread on the hottest r34 gtr! Good luck with Auto Salon...
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989705
hey johhny thats some good power there mate, mine got 241awkw at all 4 at doms place aswell mate, hope he looked after you there mate but power is very good, just get a set of cam gears and you should get about 240-245kw at all 4s and less laggier,
cheers mate
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989716
I have a 34 v-spec II as well with 260awkw with pretty much the same mods plus a set of HKS cam gears you should gain approx 15-20 awkw from them with a wider power band mine runs out of puff around 7700-7800rpm at 14.5 /15psi boostpost-277-1215069808_thumb.jpgpost-277-1215070186_thumb.jpg
Edited by gtr13
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989817
cheers mate
hey tony, thanx man! i was gonna msg u how i did n maybe come past to see your car.
ill be doin those mods pretty soon mate, I have something to say about protek but ill keep it quiet for a bit until i post some pics of my issue.
may i ask to anyone reading this thread, when u get a power fc installed, does it mount in the stock computers position? the frame should fit it right? cos currently mine is hanging on the floor mat and i was told to use some double sided tape to stick it against the kick panel because the stock frame dosent hold it.
is this right?
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989833
omg, gtr-13 you might not believe this but i was actually just about to order the number plates [GTR-13]
you have some great power there, your soo right though, kinda runs out of puff past 7000rpm. I would only do cams if there is no loss in low down torque so ill analyse your dyno sheet more closely.
btw i also put your car as my desktop background, it looks fabulous.
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3989844
would adding new front pipes make much difference to the power ?
I'm trying to keep his cost down as a change in the dumps would cost alot , plus if you change the dumps you'd be silly not to change the turbos and then the list goes on
A front Pipe may give you a little bit, But its the dumps that will make the more noticeable difference.
but very correct on when you change the dumps.... you may aswell change the turbos at the same time..
unless your only going to want 14psi all the time, which should only last a few weeks... MOAR boost!
https://www.sau.com.au/forums/topic/226506-dyno-results/#findComment-3990993
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
