iam thinking of the same set up on my car,so what your saying is that i need a bigger pump,some rx7 injectors......how much are they? and a remapped chip,should i get one from toshi....how good are his ? or should i just get mine remapped on a dyno? ive heard this setup is good for around 230-240rwkw?
  • Replies 61
I would get yours remapped. every car is different. I dont think getting someone elses tuned computer would be good as each car has its own individual characteristics.
as for the parts: new pump around $300 - $400 regulator $200 - $300. as for injectors i havent really looked around but i think 2nd hand im guessing around $400 for the 6... not too sure
im going to try with stock injectors.
remap really depends, ive heard around $750 is about the usuall going rate.
If u are going to go more than 230rwkw you will have to change injectors i think, i would even consider possibly a bigger turbo than a 2530 - to make it a little easier, but remember the 2530 is very responsive anything bigger and your power range will be alot higher in the rev range.
well im not too sure to be honest, i asked for an 044 but the guy getting it reckons thats over kill he rattled the name of it but i cant remember. something like 58... i dunno its about $300 (and thats with some sort of discount) it supports alot more power than i need and fits in-tank easily.
Have you put yours on the dyno yet?
I just put a bosch 910 in my car. After installing the td06-20g turbo the car with the stock ecu and fuel pump was getting very lean towards the top end of the power curve. The new fuel pump really made a big difference, now the car runs much more richer. So instead of forking out for injectors I'm gonna do the ecu with just a fuel regulator and try and keep the car to around 350-370hp. I'd love to crack 400hp, but if I crack that I think I'm gonna have to crack open the engine and put better internals in. The pump was $220inc gst and fitting was around $125inc gst.
yeah they are very cheap.
I just got the sexy sard regulator. probably a bit wanky, but it has anodized blue fittings and machined look. i got it very cheap tho with the skyline adaptor plate. so it fits straight in too.
Im just wondering whether the car cut out due to an airflow cut or because it sensed the pump couldnt cope...
anyone know if skylines do have fuel cuts? because i was running higher boost with the std turbo.
ECUs that are re-mapped on a bench arent exactly the best way to go. It assumes a lot of things concerning your engine.
It can work and im sure it has worked for ppl out there, but as an absolute minimum i suggest you get your car dyno'd to check A/F ratios once you have your bench written ECU installed. Just to be sure its not way off.
The beauty of getting car tuned on dyno is that the good places (read expensive) monitor fuel rail pressure and flow, injector duty, use forms of knock detection etc etc to be sure that the increase in power isnt going to shorten the life of your pride and joy.
i got my Sard Reg from Envy imports. they had them in stock with all adaptor plates and fittings for standard 8mm hose or threaded fittings for braided line.
very helpful and had what i needed in stock. they even ordered the pump i wanted and i received it that very day.
i hate having to wait :P
Yeah they are actually cheaper. they have the Reg with the skyline adaptor (usually $30 or something) with fittings for $330 total
i was pretty stolked with the price as most other retailers were selling for $340 without adaptor or fittings
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG is has not responded to my emails so far after purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
