  • Replies 131
i cant believe vic doesnt have this thread already. i for one am a fan of Ali's in doncaster. he makes them so damn good. lambs on chapel are also up there. theres one on spaghetti junction (s'vale, police, and princes) thats good too but the quality varies a LOT.
oooh yeahh!!
lamps on chapel and also on high street in notrhcote. the best spit roast lamb..
also try KATIK on Barry road in broadmeadows/campbellfield. they are hardcore. the best is an Adana kebab they are roast over charcoal beads and are super smokey. plus they claim to be the best adana in aus or something, and i would not argue.
https://www.sau.com.au/forums/topic/227871-kebabs/#findComment-4010300
haha they are my top 3 too, havent been to ali's since last night lol
lambs is by far the best though
https://www.sau.com.au/forums/topic/227871-kebabs/#findComment-4010406
Yeah, ended up on Haci's a few times, when hangin out with mates up on that end...
Lamb on Chapel is still a fav tho...
which is the one on Springvale junction? U talkin about the one a bit further up from the actual junction itself?
https://www.sau.com.au/forums/topic/227871-kebabs/#findComment-4010686
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
