  • Replies 131
kababs... hahahaha... victorians are still cracking me up... im used of calling kebabs... a yiros.... anyway back on topic... lol
i get the "kebab" pizza from ashley st, West footscray..... or just sa regular "kebab" from summerhill rd $4 car wash.
hahahaha.... kebab...... lol..... just like dagwood (dippy) dogs. lol
https://www.sau.com.au/forums/topic/227871-kebabs/page/3/#findComment-4012321
I'm feeing the need, the need for another Kebab cruise, so sad I missed the other one, my car was away being tarted up :)
Let's have another!! :thumbsup:
Take the top 4 shops, make a poll and we'll do an open cruise there, what do you say?
make it a saturday night and im in.....got a mate who would love this....lol
https://www.sau.com.au/forums/topic/227871-kebabs/page/3/#findComment-4012567
Will do, I know fark all about Kebab's so we need to sort out the top 4 places then I'll make a poll on it :thumbsup:
Organise the cruise to go to all 4 kebab places... then have the poll after that night.. then we will know who’s kebab reign supreme.
https://www.sau.com.au/forums/topic/227871-kebabs/page/3/#findComment-4013412
Mate, bloody awesome idea. That's a winner. We'll buy one at each place, divide it by, say 4 ppl and rate away!
I shall call this event Kebab-a-palooza! Will get cracking on this one. :)
https://www.sau.com.au/forums/topic/227871-kebabs/page/3/#findComment-4013802
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
