AWESOME Andrew!!! :ninja:
Have you thought about Targa? Decided to enter Rookie to see if you can win modern to get the full entry for 2010 or just goin the whole hog?
Yep I'm looking at this Wrestpoint Rally, Targa Rookie and hopefully Mt Buller for 2009. Not sure about trying to win the Rookie however since neither me nor my nav have any Tarmac Rally experience so really we are just going out to learn what it is about and to have some fun and most importantly bringing home the car in one piece next year.
I'll probably be getting in your ear a bit over the next few months though as I try to sort all of this stuff out. Even this entry form looks daunting :P
Are you using the blue car? Be interested to see what you needed to do, full cage and all the other bits and pieces.
Yep using the Blue car. Already have been down to see Toby at Merridian to sort all of the safety / other generally rally stuff out (car will be down there in the next month or so to get it all done) and have also chatted to Benno about what I need to do to bring the car in-line with Rally regs which will all be done when I fix the diff. It's actually not so bad these days with the AASA rules (given things like oil coolers and radiators are much easier now).
So.....Wrest Point - im keen as mustard!
And for $2k you cant really go wrong given the amount of K's driven
EDIT: I rang the number on the bottom of the email to find out the exact rules regarding cages - does anyone here know 100% what the rules will be? I have a bolt in half cage sitting here i can put in, not really looking to get a full weld in cage
Ok, ill have a look at what they cost and weigh it up :P
Helen came and asked me about half cages and R32 GTRs so putting two and two together she will call in the morning suggesting a CAMS approved Bond bolt-in system... allow $1200 for R32 kit. They are pre-fab and generally in stock ready to freight. No cutting trim required even with side intrusion so no real resale killer.
For a decent weld-in allow atleast $3500.
you're 3.0L motor isn't going to be all that legal either mate btw.....
Ok so thats a definate on the full cage....
Hahaha, thanks for that ill mention i spoke to you when she calls back :D
As Snowy said, ive got an rb30 bottom end, so it looks like i cant enter anyway - unless there's a class for people who just want to have fun and dont take it as seriously as the guys at the pointy end of the field?
Cheers :)
there is steve, mt buller sprint. its a drag race up the hill, about 8minute run and you get a heap of passes over 2 days. It doesn't run under these regs and allows more modified cars.
cool, helen is good value.
funny you should mention that... for 2009 with targa tasmania and targa wrest point we are introducting a class that will allow people to compete with modifications outside the tollerence of the technical regs.
providing cars meet all the safety requirments eg. cage, belts, kill switch etc you can run all stages at unrestricted pace, compete for a targa trophy, but not be classified under the final results.
That sounds like a good class :D
So in this proposed class for example, you would allow single turbo conversions on GTR's, Rb30 bottom ends, different gearboxes etc - that kind of thing? Or less mods than those :blink:
Looks like ill have to wait another year
Good news! Be keen to see what these rules entail Stu.
And you'd want to drive that through the trees without a cage....
You're pretty special Sunshine :D
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
