Hey Kel,
Looks like I will be seeing you at Rally Tas, just got the call up last night. Hopefully its a quality event, as numbers are low.
Good luck everyone competing in Wrest Point, won't be able to make it down now to spectate :D
good luck guys , i will be looking for results intently
you better get that car of yours fixed in time for targa you pussy
good luck to everyone competing this weekend, especially the rally virgins.
and looks like toyota have pulled out of ARC. very bad news for rallying in Oz even tarmac style, they were the last manufacturers hanging in there
Well touch wood that the weather stays as is forecast right now for the weekend. It doesn't need to get any hotter (or wetter) than is predicted currently. I'm really glad this event isn't in Melb though as there is no way my car would survive 40degs. It nearly died yesterday just driving into town!
And the boys and girls are just applying the final touches to the car now. Paul Walker would be proud! :(
nice work on rally tas Tim! Shame we wont see you this weekend?
Just spotted Snowman out on reccy - that crew car is definitely hard to miss we were in the navara with the smoking brakes going the opposite direction :blink:
Looks like we are in for some bloody quick stages going to be awesome fun in the 35
Anyway back to work for me gee this nav thing is a tough gig
Stay safe and legal Kel ;)
I've been getting reports that the stages look good, you better be heading to Joe's Garage tonight for Thirsty Thursdy!!! :blink:
Ha ha always safe, no comment on legal :)
will have to see about joes we still have to do some set up including seeing if i can sqeeze my arse into petes tiny seats!
What a day. 5:15am wake up call from the idiot on the P.A. system on the ferry, followed by a drive from Davenport to Hobart to check in, followed by a 380km recce trip. Am utterly rooted.
But so far it looks like fun. I think. Am too tired to tell. Off to bed....
But RS4 is a tops recce car :)
We're at the business end now!
Scrutiny began tonight and continues tomorrow. Some last minute mis-communications have resulted in the Cygnet stage being chopped up pretty heavily by council contractors... I have been assured by council all will be good, but a visit to the stage late tomorrow arvo will seal its fate.
Turns out I'll be on the course now... I've got flashing lights, a siren and borrowed car to play with !!
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
