That would be our black Skyline which my lovely wife was running at the event (car 832). She was going very well until the motor started to miss Saturday afternoon, finally dieing first stage Sunday. Not sure on the problem yet but heaps of blue smoke from exhaust and oil breather, so maybe piston/rings etc.
Any suggestions on pistons etc for the rebuild from those here smarter than me? I think pistons and a 1mm overbore are now allowed in EM rules? The block is genuine N1 (24U) so hopefully rods and crank are ok?
Many thanks to Adam Spence and the Mazda boys for taking the car back up the Island, and all the other rally people for their help on and off the boat etc.
cheers
paul
there's your problem. everyone that gets #832 has trouble. Right TT?
Thats a lie, I spotted a TBSM.com sticker on the rear quarter window :P
Ahhh yes forgot about those, well if you want to be anal there are two tow stickers on the car too and our names on the window. Blue triangles are on magnets and taped down :thumbsup:
All john says is "f**king giveittoerr!!!"
not quite right savman, big John is a bit of a churchy so he prefer's flopp'n or flip'n, ya don't hear the proper F bomb till your in the bar with him at around 2am....
yep i remember the car, nice and clean but the one thing that stuck with me is, the mint pair of oakley frogskin's the driver was running for the weekend........:thumbsup:
cheers
paul
You know you have teh coolest wife ever right Paul?
Hope the run to Targa Tas is not too painful
Ron Jeremy = hairy fooker???? :)
YT and I were recce'ing a tricky section, and couldn't work out a way to call the notes quite right, so figured a bit of "Left 4.5 immediate Ron Jeremey" would remind him of the section :) .... Gosh I wish I was there to hear Big John read it..... LMFAO
Its either that or it was a big balls section!
Mind you - looking at his in-car every bloody corner was a big balls section! :)
But I have used random phrases or terms for some corners or sections in the past so I remember them.
Nothing as unique as Ron Jeremy - but I did use Cartmans "Respect My Authority!" phrase to note the start of the skinny section of Merseylea.
glass is in today, should be driving on the road on the weekend. Aim to enter the hill climb on the 12th Feb for the start of testing
am trying to chase sponsers though...which isn't easy when you don't have a car to show off.
Haha they are a little bright you could say...
Going to put the entry in for high country soon to secure a spot, it's still so far away though.
And there I was thinking I was the cool one in the relationship...
It is going to be very busy now till Targa, hopefully the car will be back early next week and we can get it apart quickly and find out why it happened? General consensus seems to be fuel surge? We have a couple of broken rear shocks to sort out too, and only 6 weeks and the car is back on the way to Tassy!
New's just to hand EM has a new competitor, Peter O'Keefe of black Torana fame (car 636)
he has just bought the X White Hot R34 GTR road car, and is currently getting it ready for an
all out attack on Targa 2011, will be intresting to see if his driving style suit's the GTR,
or will it run out of tyre's.....
Thought's???????!!!!!!!!!
Interesting that he bought the old road car rather than the old race car which is up for sale again.
But it'll be good to have another GT-R on board. Those pesky EMO's are getting far too cocky in EM now.
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
