wheels of choice for a 32/33/34 gtr in targa with bigger brakes?
I have alcon's (365mm) and heard nightmares of finding wheels that fit over the caliper
obviously would have to be 10" wide or less to be legal. no idea what to do with my weds 10.5" rims.
We ran the 365 Alcon package under 34 wheels, you can see there was some issues with foreign object clearance (always is with big brakes and rallies) but they cheared fine.
Wheel is dependant on whether it is a 32, 33, or 34, as they obviously all had differing sizes from factory.
The supp regs clearly state for Early Modern;
Early Modern & All Classic: Wheel diameters may be varied by a maximum of plus or minus 2” and wheel width varied up to 2” from the standard dimensions. Classic vehicles may only increase sizes up to maximum of 18 x 9 inches.
So, R32= 18x10's
R33 = 19 x 10.5
R34 = 20 x 11 (full hectic)
Edited by Marlin
So, R32= 18x10's
R33 = 19 x 10.5
marlin, R33 would be 19X11. as they had 17X9 stock.
it goes:
R32 16X8
R32 Vspec (some run as this I believe?) 17X8.5
R33 17X9
R34 18X9
so just add your 2X2 to those.
Yeah you're right Baron.... I knew that after I posted it, but you got the drift ;)
It used to be 1 + 1, We had to run 17 x 8 on my GTS-t, now we have 18 x 9 which makes me happier trying to catch the Evos (in the dry at least) :)
32 vspec was 17x8 - so 19x10 max not 10.5.
The +2" wheel width is one of the worst things about the current rules....everyone has to spend more on tyres because everyone does, and the crashes are harder.
Blaise reckons one of his biggest advantages was being able to run bigger rubber than the rest of the EMO's (he squeezed on 255 rubber onto his cars where as the others were all on 245's).
The funny thing is for me my tyre choice was the Yoki A050's and the biggest they have been making is 265's. I have a set of 10.5's and a set of 9.5's and I personally found that the A050's in 265's sat better on the 9.5's than they did on the 10.5's (where as the RE55's and DZ03's were both better on the 10.5's in a 265 tyre).
But as soon as the 295's were out I'd have been switching to them on the 10.5's as my preference.
^^^^ My gut feel on the rubber issue, was the bigger tyres gave me more rubber to wear down so hopefully longer tyre life. Made me more confidfent of getting to the end on the one set of mediums. Turned out tyre wear was definatly not an issue for me, but it is a light car with moderate linear power as opposed to the heavier GTR's and bigger HP.
But for outright pace, I did do back to back testing between 235's (what most emos run) and 255's on the same day and there was two tenths of stuff all in it. I went about 0.4sec a lap quicker at best, but also had gone from worn 235's to new 255's so not sure if most of the gain was just that I had fresher rubber. Wasnt a massive improvement, but at the same time cant be a bad thing. Most forms of motorsport if given the opportunity, tend to run the biggest rubber they can.
Greg Garwood is looking for a good tarmac prepped R32 GTR if anyone knows of one?
Yes, I've told him about Jurgenson's and I'm sure he'll follow that up. - edit - Drew doesn't wish to sell now.
Edited by Marlin
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
