Heya all :)
External (wet) oil pump setups. Legal for tarmac?
If so, who's using what setup?
I currently have oil pressure issues and am looking at my options. The pressure drops suddenly, not to deathly metrics, but it drops from time to time with a bit of thrashing. I'd rather fix the issue before it drops for good.
I have a spanking new N1 pump sitting here and I'm considering the Reimax gear upgrade. I have a 32GTR so I also need to mod the crank which means it's a good time to rebuild.
I don't really wanna spend the money on a full build just yet so I'm considering modding the sump (bigger, baffled and gated), throw on an external pump (sell the N1 pump) and keep driving the nuts off it till engine bits end up on the road.
Sorry for the long spiel. Purple monkey dishwasher.
Mark :)
Hi Mark,
this is a bit of a handball, but if you are building a car its well worth reading these regs....a few times.... These are the 2011 Targa Supp Regs. Word on the street is there isnt major changes to these at present so if you use these as a guide you should be sweet.
Off the tops of ym head I am pretty confident you are sweet with the sump, just dont knw about the oil pump, but I am sure its in there. If Stuart drops past I am sure he will have the answer.
Targa Supp Regs
Edited by Darkside
Hi Mark,
Targa Supp Regs
Thanks DARK!!
Why read the regs?? It just shows how much everyone is actually cheating! hahahaa
General regs state:
82. Sump / Oil Filter (except Showroom)
The removable section of the sump maybe modified to increase capacity and internal baffles may be fitted. Sump pickups maybe modified to allow for modified sump depth. The oil filter element/cartridge/s is free, providing the cartridge fits without modification and does not perform any function other than filtering the oil.
With no additional info in Modern LMS
I see an external pump (wet setup) as a reliability modification without any performance advantage.
It saves me stripping my early RB26 crank out and modifying the crank collar and spending $$$ on a crazy oil pump. This way is just a sump mod, add external pump, say 3-4k all up, and it's done for ever. Unlike removing crank which means bottom end rebuild at the very least.
Stuart, any comments?
I believe reliability modifications can be discussed and agreed upon outside of supp regs?
Mark :)
With all due respect, the rules have been like that for years and happily accomodating GTR's for years too.
If you're concerned about the cost of a fresh engine and or oil pump for an event such as Targa, well, I'm a little flumoxed.
A few grand spent up front to hopefully ensure you actually finish what is an endurance event that WILL cost you 15 grand minimum before you scratch it or renew the car to it's former pre-Targa state (tyres, pads, bearings etc..... )
To take short cuts on reliability is a little wierd.
EDIT: I just properly read your latest post and its clearer where you're coming from. My post above was more in reply to your earlier post about external pumps.
I understand your concern about the pump, but as i say, hundreds have done it and lasted no worries previously. And I maintain that you'd be mad going into targa with an original R32 engine.
Edited by Marlin
Heya MARLIN :)
I'm asking about external pumps as they seem to be a near ultimate fix to any RB26 oil pump issues.
I should have given more background. My car is currently a rego'd thrash/track bitch with the intention of doing some tarmac in the future.
I've recently picked up and oil pressure issue and can't afford to build a motor right now (Early RB26 crank collar required = bottom end build). However I can afford to add an external pump and mod the sump as I can move these mods between any engine and it allows me to drive/thrash the car, until I can afford to build the motor the way I want and start competing.
I just don't want to back myself in to a corner by using an external pump in regard to competition rules.
I'm sure you'd agree the external pump is as reliable (if not more) than a replacement pump, hence my question. It also saves me an immediate bottom end rebuild (to fit crank collar).
Sorry for the long reply, just my current thought process!
Mark :)
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
