hey,
car is now going. Changing gears is some what tempromental. I change gears, and get crunching. Could this be due to gearbox not having right oil in it.
i have used some castrol 75 W 90 W gearbox oil.
am a bit worried it could be stuffed, with a synchrose, but the gearstick does flow into each gear pretty easily.
any thoughts. or recommendations....
https://www.sau.com.au/forums/topic/22885-gearbox-feels-like-shit/
how much oil did you put in? because i was having the same problem....but mostly going from 1st-2nd...
its really important to only fill till it spills out from the filler on a FLAT surface...cause first time i changed mine i didnt lower it back down to get rid of excess...
did that last weekend and i had about 400ml too much and now it shifts heaps better....
im kinda having a little of the same problem too.. when i first take my car out in the morning when i go from 1st to 2nd, 2nd feels really tight but after about about 5 minutes of driving it loosens up and goes normal. what up with that huh. also sumtimes when your driving kinda normal and in 3rd changing into 4th it wants to jump out of 3rd while your changing..kinda like it cant wait to get in 4th.. what do you stooj`s reckon
Its got to do with the viscosity rate of the oil.When the oil is cold,its thicker which makes it hard to change gear but when it warms up,it thins out and gear change is easier.I know its expensive but try fully synthetic g/box oil.problems will be fixed.
I just did the gearbox oil on my R32.
I bought REDLINE lightweight Shockproof.
It's excellent.. I can't recommend it enough.
my second gear use to crunch but now it doesn't do it at all.
anyway, that stuff sells for $25 per litre.
I just bought the 3.78L bottle, $100.
The R32 GTST gear box takes 2.8L for those who are interested.
I know $100 sounds expensive at first, but when you consider that you change your oil every 5000kms and if you are using like MOBIL 1 synthetic, it costs you at least $50 each time.
how often do you change the gearbox oil?
It's a very good investment...
I found my one from Croydon Racing Development (or whatever they are called now...in silverwater, sydney)
i bleed the clutch lines again. and the brass button feels a lot better....
But then the clutch pedal welds snapped. So the metal casing which bolts up to the car makes the pedal stick behind the brake pedal.
was lucky i was only 2 minutes from home when it happened.
i am gonna do the gearbox oil again...
Does the clutch grab right at the floor ? does it feel like the clutch is not disengageing proply?
This happend to my car when i converted it to manual too.. my mate made me a adjuster that works a treat. he will sell one to you for a price. pm me if interested
It fixed mine RIGHT UP i was stoaked!!! now i gotta fix 4th and 5th gear syncro in box ;)
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
