yeh thats our car...my old man discovered sau and is slowly learning about online forums lol....so he has been doing his own thing on here. Hopefully in a few weeks we will have a new motor that will hold together! But in the long ass wait for the machining to happen we have been working on a few other things to hopefully make the car abit quicker/reliable/tidier and more fun to drive.
  • Replies 148
Very nice setup Darren ;)
The beast should be fun on the track.
We should put a SAU GTR team into the Queensland 500 Team Enduro at QR. It should be fun :laugh:
Hey mate will definatly be keen on putting together a taem for the QLD 500 I would say Mark and Russ would be more than interested aswell. Would be a great event and I think a team of GTR's would do really well in that event. I will be catching up with Russ this weekend sometime so will gee him up and will have a chat to you about at the next track day.
  • 4 weeks later...
How have you found the scavenger from the rear of the head??
Im using -12 scavnegers and a -10 from the rear of the head.
I was concerned about the feed not getting enough oil at lower speeds and damaging the pump so ive left the oil restrictor out for the time being.
Curious to know your thoughts??
Not had any problems with the scavage of the head as the pump does not need a great deal of oil in the scavage stages to keep it properly lubricated. Have run the same dry sump set up on another car that i have built that has done quite a few klm's now and works a treat. With a dry sump set up you should not need to run a oil restrictor in the block so you should not have any problems.
The wiring is for the motec is around 3/4 done at the moment should be done by the end of the week or early next week and then will be getting a tune so should have some results by then providing no little hicups pop up.
  • 1 month later...
  • 1 month later...
Hey guys a quick update. Had a few little issues with the car wich i should now be on top of. Unfortunatley though i have been unable to dedicate much time to the car over the last few months due to work commitments the ecu install is done and have performed some cold start and light throttle tuning. I will hopefully get the time to get the full power tune done early in january as my tuner is back on th 12th so i will be trying to get the car booked in first cab of the rank.so will hopefully have a some results to post up before to long.
Angus the fuel pumps are working without any problems though this has only been during light load running in.
Bosch pumps are always a little noisy but this seems fairly unavoidable.
Though I have run the same fuel system in another GTR that i have built that has done some serious track time without any problems. The fuel temp does not seem to be a problem but if you do have any heat issues with your fuel i would recomend checking your fuel reg as I have had some drama with fuel temps while running sard regs as they seem to restrictive for high hp aplications once changed to a larger free flowing reg the fuel temp issues were no longer a problem. Hope that helps Daz.
  • 1 month later...
  • 1 month later...
Hey all just a quick update. Have had a few headaches with the car got it on the dyno and did all the light throttle and cold start and then started to give it a few power runs.
This is when the drama started to unfold with 1bar of boost as soon as it would get to 5k rpm it would start to push coolant out of the radiator but the car never ran hot. So off the dyno it came to get to the bottom of the problem. It had built up so much pressure in the cooling system that it had started to baloon the end tank of the radiator. so pulled the engine out and stripped it down. Had the head crack tested all ok deck of block dead straight. I could see slight indication that the head gasket had lifted. After a bit of head scratching finally found the problem was a faulty thermostat it was opening enough to circulate thru the cooling system at lower rpm but causing a major restriction as soon as rpm was lifted. This would have contributed to creating a weak spot in the gasket allowing combustion pressure to finnish the job. a bit odd thou as I would have thought that the pump would have cavitated or radiator hoses would have let go first ( they were balloning and makeing an attempt to let go but somehow managed to hold on). Car is now back together and all seems fine have had it on the dyno breifly and have driven it for a few klm's to check coolong system is operating as it should be. and all seems good.
Now just waiting on my tuner to get back from dubai / shrilanka to finnish off the tune so finger crossed i will have some results within a few weeks. Have also purchased some new suspension components for the car so will post up some pics soon.
Bloody heck that's some rotten luck Darren! Difficult problem to isolate too.
Regarding the hoses not popping first, funnily I've also experienced a similar thing many years ago as a young fool. I was doing many many donuts on the mudflats in a KF turbo 4WD Laser until it was really cooking, and instead of popping a hose or gasket the radiator tanks burst right off it.... big bang!
Glad you found the issue and you can move on mate :P
Car looks great mate!
A lot further along than mine, but I'll catch up eventually :)
Great work, and I can't wait to see more updates! Shouldn't be long before we see this beast terrorising unsuspecting Porsches on the track :(
A lot further along than mine, but I'll catch up eventually :thumbsup:
Great work, and I can't wait to see more updates! Shouldn't be long before we see this beast terrorising unsuspecting Porsches on the track :)
Thanks guys is coming along but as we all know these things always take longer than expected especially when you run into drama's along the way
That is the plan. I have all the confidence in the world that the car will be more than capable will just have to see about the driver though in saying that there seems to be a lot of accountants and companu ceo's driving porkers that would definatly fit into the same catagory.
Edited by dazmo
    • Resizing injectors in Nistune can be done a couple of ways, and there are a couple of ways that you can make a mess of it. The tuner needs to be really aware of the effects of whichever approach he uses (either K, or TIM). They are both easy enough to "get the injector size right" to run the engine. But little details like old start enrichment and hot start are affected differently, depending on which boxes you check.
    • Pretty safe to say almost everyone that has tuned their own car has experienced this issue. The difference being that we have our laptop in the car and when it happens, it's literally 10 seconds of tuning to sort it.  Would you be happy to plug in your laptop and sort this yourself? It is a very simple process and there is no risk of harming your engine (if you are worried about that).
    • Yeah thats the next step now, either they wil or i will take out for a drive to work and go straight their after work and see is we get the same issues 🤞  thought i try my luck here too, never know someone else might have had the same issue but thanks for the reply
    • Basically your tuner needs to drive it for the 30 min (or whatever) to create the same conditions then check the ECU settings and sensors at that time. They may not be excited to because that takes them 30 min rather than just opening the bonnet and seeing the problem straight away.... Hot start is generally not as tricky as cold start, but there would be a table for fuel enrichment vs coolant temp as a starting point
    • Yeah, they all cant say anything for sure as everything is working fine . Said unable to find an issue untill it stops again. Could mist likely be CAS wiring or IAS valve issue but again not 100%
