I own a skyline gtst and people are always trying to drag race me with 4wd cars. Gtrs, Pulsar gtir ,evo's ,ecpilse etc.
First of all i do know that Gtrs are the top dogs. and I'm planning on buying one in the coming future.
If it wasn't for this unit i would stand a chance.
check the link out and please give use you thoughts on the unit.
http://www.world-motorsports.com/products.php
  • Replies 46
Its not clear to me how exactly this thing works. I like the operating method of the Jaycar boost controller which is triggered by the duty cycle of the injectors and can absolutely eliminate any boost going to the wastegate actuator until you want it to. I am about to install my Jaycar EBC (at about half the price of the above - although that is for the build it yourself kit) - people who have used them say they work as described so sounds ideal to me.
This is not to say that the new device mentioned above is no good - it is just not clear to me that it would be better.
Its a boost controller
Its the same as any other boost controller - it controls boost.
So whats your point?
Its no better than anything else save for the expensive price tag
Yep they will do that.
So let them race themselves on the street and save your fun for the race track where it belongs.
That boost controller has nothing special about it at all.
Eclipse? As in the Mitsi? I thought they were FWD?
Read before you talk the same advice that you gave me then you'll see the benefits
lol so what everyone at performance mag. don't know what there talking about.
(ignorant as i thought.)
see if any GTRs can hit these times
This is a 4WD eclipse and this is one of his bad times
keep on dreaming GTR fans show me something better. (thats real)
I'll give you the world wide web to find a GTR as fast as this, don't even think hks skyline. when you all find one, I'll show you the last video thats not on the net.
so step up
Dude why are you showing clips of 7 second prepped drag cars as an argument why a boost controller (which is the same as any other) gives them an "edge"?
For the record, the fastest GTR @ present i believe is the 7.57 @ 191mph by the Heat Treatments GTR.
Is that not faster than the vids you posted?
Or am i again, missing something magical and elusive?
I honestly think you have NFI what your talking about
let me guess was it build in australia.? lol
the car has ran a 7 sec flat and keep in mind that everything about the car is quarter the size and price.? i guess you can't beat that.
i guess that is why the australian dollar lost its value.lol in the last 10 years keep up the good work guy's thats why the japs rule there more open minded. selfdevlopment, most of you should work on that.
    • Block bump. $400. As above cyl 6 needs bore or sleeve.
    • I would think making the argument that the travel is limited by a spring flexing against a spring perch as "the same method". Later on in the document they do state that the spring can't bind on full bump travel and cannot come loose in full rebound travel as well. (which is all very sensible). The laws are actually pretty sensible and reasonable. It's just that the people who enforce and check them don't actually read them or know them accurately. "Oh, coilovers? Instant fail mate. Don't even need to look at it." - Guy who will be instantly reported by me. There is probably merit to people who do get defected for height also get defected for the suspension in that state that allows it. I did never consider the people who are complaining about coilovers being picked on are also running around at 50mm off the floor.
    • I think given SAU's knowledge of E85 we can strongly conclude that 10% ethanol in almost any situation is entirely fine. Almost all of the myths against E85 were overblown, let alone E10.
    • From your link See bold text, is this referring to damper settings, if so that may a issue for "some" inspectors, I cannot see aftermarket coilovers having the evidence that "must be available that its functional performance is equivalent to the original" Maybe just remove the adjustment knows and hope for the best???? Meh 5.2 Suspension travel In all instances, modifications to a vehicle’s suspension must ensure the integrity of the system and not compromise the ride quality. At least two thirds of the original suspension travel should be maintained in both directions (rebound (i.e. extension) and bump (i.e. compression)), and rebound must be limited by the same method used by the vehicle manufacturer or if this is not practicable due to the nature of the modification, an equivalent method. If an alternative method is used, evidence must be available that its functional performance is equivalent to the original.
    • They actually don't - They adhere to VSB14 rules just like Victoria. The rules are against CABIN adjustable height, and it quite clearly states that the height has to be within parameters. I asked the VASS engineer to confirm this when I got my car engineered and they refused to engineer the coilovers because they didn't meet the requirements for requiring engineering. (mine are height adjustable.) People "Not wanting to bother" with "Actually reading/knowing/adhering to the rules" should result in fines and immediately losing the ability to issue blue slips and/or RWC's in Vic.
