For those wanting the jap c34 manual
Please PM
download the torrent and use a program like utorrent to download the file (links your computer to mine to grab the file for those who don't use torrents)
enjoy
yeah i've managed to grab about 82mb so far. i've also uploaded about 90mb. i'll continue to seed it for a while, i'll also upload it to usenet for anyone who prefers that, i know i do. cheers for the upload tom :D
Edited by QWK32
will do once a few ppl have it
also downloading ABBYY finereader, should be able to scan the pdf and pull all the text from it and spit it out so it can be translated into ingrish
yeah i've managed to grab about 82mb so far. i've also uploaded about 90mb. i'll continue to seed it for a while, i'll also upload it to usenet for anyone who prefers that, i know i do. cheers for the upload tom :(
guys, try and not seed it out to the world. it is illegal to be distributing copies of the books, so just be aware of the consequences.
there's a reason it's been kept on a word of mouth level so far. don't shit in our front yard mmkay?
hey shan, what are the forums policies on posting links to this kind of document? while i would tend to agree with what you said, im a little confused by the fact that you can easily download anyone of the R32,R33,R34,etc workshop manuals from a number of sites, i think i've even seen them hosted by other nissan forums. you can also buy a copy off ebay, which is clearly one of the copies floating on the net that someone has downloaded and burnt to a CD to try and make money. i guess im asking how illegal can it really be, i mean they cant just be lucky to have not been caught yet.
Is usenet a hosting site? I don't partake in torrenting so if there is another way..
nah, usenet is something different, i wont get into the nitty gritty of what it is because i only have a basic understanding myself. basically anything that is available on torrents you will find someone has also uploaded to usenet, but you download from servers and not other people, so you don't have to wait for people to be online and seeding to get what your after and you always max out your internet connection, i see down speeds of 2.4mb/s (which is my max downspeed).
to get the files you need to have access to the usenet newsgroups, the binary section in particular. there are a few service providers out there and yes you have to pay a small fee for access, i pay $10 a month for unlimited access. you also need a newsreader capable of downloading binaries. so probaby not worth it just to get this one PDF. i might look into getting it up hosted somewhere.
Edited by QWK32
we don't allow any linking to any copyrighted material. regardless of who's doing it and who's getting away with it. we've been contacted by JPNZ before asking us to take down links to manuals before. Not so much Nissan Japan about their workshop manuals, but it's still copyrighted and illegal to share. So therefore blanket rule still applies.
Same reason why we took down a for sale ad for Blue Ray DVD's a week ago because they were all illegal copies. We just don't want to be labeled as a medium for that sorta stuff.
If you're gonna share URLs, please keep it to PM's. At least that way it's out of the public eye.
too easy, thanks for your input Shan :P
  • 1 month later...
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
