She's going good. Pretty much anybody can drive the car now. This clutch is just so easy to drive compared to some others.
Hi Richard, you have the Super coppermix C twin?
I found as my mods started to give the car some torque/response, the OS Giken Quad clutch became much easier to use as a DD and I have no doubt it will be even better after the stroker build BUT from what the blokes have said that have a similar set up, I would be nuts not to get a quality sprung twin clutch that will be more forgiving on the box.
I will have to think of selling off the leftovers, the RB26 block, the motor mods and clutch have only 3500Klms, forged internals etc and I do not want to bring any of them back home with me. So once I know what is coming off I will go to the for sales thread.
Yeah your heading down the right track in regards to clutch etc.
I just changed from an OS giken triple , just like your quad. It destroyed more than half a dozen gearboxes including 2 OS Giken gearsets. I loved the feel of it and had no problems driving it, but anyone that just hoped in to have drive did struggle a lot!!
Hopefully the sprung centre will be the difference and help the rest of the driveline.
Yeh , had a few blokes talking up their driving skills and I gave them a drive when I first got it home, they could not get it going to get into second, made me feel a bit better after my drive home from Sydney when I bought it,1 1/2 hours in peak hour traffic,F, it was less than a fun drive in your new car,haha
The OS triple was an expensive exercise for you :( but I guess you were giving it heaps and loving it at the time :)
My Quad is OK as a DD now with the changes I have made but from what the boys have said and what you have experienced I would be stupid not to have the clutch changed while I a having the build done.
Trouble is now I have to wait to get it done :(
Low ten :D
When did you last bleed your 4WD ?
Pete Paul has a build thread
Here http://www.skylinesaustralia.com/forums/topic/397676-piglets-rebuild-of-his-busted-tomei-28/
I also not sold on spring centres in high powered 4WD, twin plate yes sprung centre not so much :(
I do it every 10k, it is fairly easy to do when you have seem it done, with the power you have use Trans max Z or even RP Syncro max in the transfer case and the Matic D in the ATTESA
Paul, its to do with how the spring setup works and how hard the springs are, the spline rotates inside the clutch disc with only the springs there to stop it, now this is fine if the springs are strong enough to absorb the torque but if not them the spline will rotate till the springs bind then the box takes the brunt of it if the clutch can't slip and by the time the springs bind the clutch is already engaged :(
Tougher springs?
Makes sense... But where is "the limit"?
Thats why I not sold on it, cause I have no idea how far you can go with it before it becomes a potential problem, I know I feel happier with the I sprung triple in my 34 then I would a sprung one, I know I felt it with one of the single plates I had in the 32
I am very doubt full all the springs are identical, then that might be the torque rating the clutches have is referring to ?
Tuffer springs or extra plate ?
So IF the springs aren't strong enough to absorb the shock, then it would be the same as unsprung? Wouldn't it? No better, no worse?
What's wrong with Matic-D ? Ive never had any issues with it. Whereas when I tried some others that were recommended they didn't handle it ( boiled I think )
Depends how hard it hits the wall ( spring binds ), at least with the unsprung clutch you can slip it till its loaded up fully, but hitting the spring stop would be like slipping your foot off the side off the clutch pedal while its on the floor boards giving the sudden jerk, again this is just one of my crazy theories and no real proof of it and would depend on how hard you are over powering the springs
Matic D is basically dextron III, not exactly same but very close, where Trans Max Z and RP Synroc max are designed for higher then normal loading like towing a caravan and stuff and while you don't have any issues with it and most likely never will I like the idea of having something designed more for what I'm doing with it
Low ten :D
Thanks Mick, been having a look, lots going on in there, I think I will croak before I finish reading it all,haha
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
