Depends how hard it hits the wall ( spring binds ), at least with the unsprung clutch you can slip it till its loaded up fully, but hitting the spring stop would be like slipping your foot off the side off the clutch pedal while its on the floor boards giving the sudden jerk, again this is just one of my crazy theories and no real proof of it and would depend on how hard you are over powering the springs
Matic D is basically dextron III, not exactly same but very close, where Trans Max Z and RP Synroc max are designed for higher then normal loading like towing a caravan and stuff and while you don't have any issues with it and most likely never will I like the idea of having something designed more for what I'm doing with it
Yeah I get what you mean with regards to the springs, guess I'm just pinning my hopes that the springs are strong enough to do their job and absorb some of the shock.
And interesting on the Transfer fluid. Good to know there's something even better if needed.
The RP has better load factorying
Been having a look at it, sounds like they have lubs for most applications :)
By the way Mick, thanks for your input for my build,all sorted and most parts are in and just about ready to go ahead with the job in a couple of weeks :)
I will post the results.
Cheers
What's load factorying (factoring?)? How did you find this out?
Haha yeah that, stupid iFail autocorrect
Jeff Branstater ( BSM ) was blowing gearboxes using the " recommended " oil so he got a handful of the top name brand oils and had them independently tested and that test came back with that result so they switch to the RP and it stopped blow boxes
Edit: to add to that the new owner went back to the " recommended " oil and blow a boxes first day out IIRC
  • Like 1
My mistake, I thought it was the same bloke you were talking about, same car different owner.
I had better make sure before the job starts to find out exactly what I need for the box and diffs.
Usually with oil changes I do not bother and just let them do what they want, but since I will have a lot of torque and not changing the box, I want whatever can help.
  • 3 weeks later...
Okay so just to clarify
What is the best upgraded non OEM Gearbox to use for a daily driver that can handle big hp?
Not really keen on straight cut gears
Has anyone used a Hollinger for a daily?
Before anyone blasts me for that question I know its a 20k box
How long do they advise kms you can run the Hollinger I heard a rumor they need to be rebuilt ever 15,000kms
Is the OS 1-5 a helical gearset?
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
