How big were your wheels before? How is the ride comfort compared to before? Nice photos btw :D.
stock 18's
rides perfect.
got more slammed today.
Update to come
honestly the comfort has gone down slightly, but handling actually feels better, aka coilovers and front camber, rear camber/toe arms.
im really impressed.
lol at buying a camera purely to take these photos for $197. POW!
How it sits rolling down the hiway, bit lower and cambered now. more to come soon!
Very nice, mate.
By the way, did you spray your front grille? What kind of black colour is it?
Edited by Victor.T
Nice JDM look you've done there, Mark. :thumbsup:
If you don't mind me asking, is your tint darkest legal?
Hi VT!
and thankyou...
I believe the tint is legal (darkest I could safely get).
It's a strange tint though.....on some angles/refraction of light it appears black, at times quite light when compared to that 'privacy glass' stuff.
Cheers!
Hi VT!
and thankyou...
Cheers!
Hi Mark, you are welcome.
I just ask because, from your photos, the front tint matches near-perfect with the rear tint (Not the privacy bit near the glass panel).
I am thinking of having the dark tint without any types of stickers on the wind screens and get my roof black (If you know the look I mean :) ). For that case, I have to have darkest tint (Not sure yet with legal or not legal :P ).
I think I know 'the look' you're after....I've seen some Strawberry Faced Silvia's getting around with the 'blacktop- look'....I really like that look. I reckon the V35 would look good with that too. (if I'm on the right track VT?)
oh...I reckon it's just plain old luck that made my glass look black on that photo occassion!
Cheers!
Cheers!
Cool. Fair enough. :)
Well, great work on your V. Any progress, please let us know, Mark.
Cheers.
Very nice, mate.
Hey Vic!
its actually a new grille all together, in gloss black abs plastic.
pretty good investment, changes the whole front end. i like it
Hey Vic!
Wow, ok. That looks really nice. Where did you buy it from?
I might also want to get my grille black in the future. :)
Ebay special, but the guys on g35 driver said this one fits best, and i highly agree.. came well packed too
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=290508184733&viewitem=&sspagename=STRK:MEWNX:IT
http://cgi.ebay.com/...e=STRK:MEWNX:IT
Cool. Thanks, mate. I will keep my eyes on it when there's another one for sale.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
